HELP! 2gen jdm b16a in 92 SI 3dr {VSS}
was doing some hard pulls the other day and my speedo and vtech cut out. started of just bouncing up and down then i took the sensor off and checked nothin looked messed up plugged back up now i dont even have the bouncing in the speedo just nothin. started to look at the vss and noticed 1 of the pins was missing and 1 of them was really bent/loose. its a 78410-SR3 EWTR3A 20261. thats what my old sensor reads and i cant find this sensor anywhere is this cause its a jdm sensor? and will any other usdm sensors work?If so please let me know been reseachin for couple days and no leads other than a few forums saying there interchangable. i used a ls vss and still didnt work. need my hatch up and running right please help.
Re: HELP! 2gen jdm b16a in 92 SI 3dr {VSS}
u can use any b series vss..theyll all interchangeable... check if ur plug still have 3 pins in it and make sure the vss has three pin in it too.. if that not the case u might have a short somewhere
1player2nv1
09-17-2008 05:08 AM
