how do you change the back wiper on a 93 hatch
i have a 93 hatch and i cant seem to find a way to change the wiper even the guys at auto zone failed ha any help would be great thanks guys also the guys at auto zone told me that the wiper size is 15 but it still looks to big???
~~~cody~~~
~~~cody~~~
O.G. triple O.G.
Re: how do you change the back wiper on a 93 hatch
You need to replace it with one from the local Honda dealership. Your local auto parts stores WILL NOT have them for the rear windshield.
O.G. triple O.G.
There is no pin to remove. Remove the black cover and then remove the "nut" at the end of the wiper arm and install the new wiper arm/blade.
http://www.hondaautomotiveparts.com/...ry5=REAR+WIPER
#11 $34.xx
#11 $34.xx
#11 $34.xx
#11 $34.xx
O.G. triple O.G.
No problem....you may be better off getting it straight from your local Honda dealership because the s/h charges is going to be more than the tax you will pay.
if you need to replace only the rubber blade, it's only like 8 bucks. i went to honda and they even replaced it for me lol.
Seagull Management
That's for the whole wiper. You just want the insert. Give them this part number -> 76732-SR3-305 RUBBER, BLADE (275MM) should be more in the $5 - $8 range.
H-T White Ops
#11 $34.xx
#11 $34.xx
So I searched around to see if I could find a photo since I don't have a 5G Civic.
This is the best I could find.
Based on this image, I'd say you need to go to Honda and buy the appropriate refill. It should be pretty cheap. It looks like the wiper assembly (which is usually replaceable) isn't removable from the arm, or at least not in a way which would be replaceable with normally stocked parts at an auto parts store.
Other threads on this:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-civic-hatchback-wiper-arm-replacement-2657582/
http://www.clubcivic.com/board/showthread.php?t=111867
Oh look, I can change this
There are two little metal stiffener bars that run along the edge of the wiper rubber blade - be sure to pop them out of your old one and put them in the new one... makes installation a gillion times easier too.
Civiclized
11-03-2005 02:11 PM
