reving problem
reving problem
i have a 93 ex coupe and i droped a b16a2 in it converted it all to obd 1 and now wen im sittin steal i rev it and it will go to 5k and the die down but wen im drivin it i cant go past 3k without it diein down but it dont die and on top of that i cant give it a lot of throttle wat could it be help me plz
Re: reving problem
a chipped p28 but i just changed the fuel filter and only once i was able to take it to 8k then it started that **** again, then the other night i changed the fuel line and it went to 8k then it started doin the same ****!!
Re: reving problem
it idles fine wen i give it alot of gas it gets to 5k and then it dies down it dont die it then starts runnin shity if i keep my foot on the throttle
Re: reving problem
Sounds Like A Possible Map Sensor issue, They do tend to act up without setting codes. did u have to cut the harness at all to extend the map harness?
Re: reving problem
Try disabling your vtec and see if problem goes away if its not the MAP maybe your not getting enough fuel or timing when vtec hits and that could cause it to fall off and it would explain why it revs in neutral but under a load at speed it craps out.could be a bad chip or calibration man
Re: reving problem
not since i swaped it in to my car. ive changed the fuel filter and it went to 8k while sittin there and then it started the same **** i then changed the fuel line and it went to 8k while sittin there then started doin the same ****. ive ****ed with the tps and unpluged it still does the same thing.
