Hytech header on b18c question.
Just want a few opinions...
Is it worth buying hytech header for a b18c type r?? The pipe is more or less the same size and all it does it eliminate the cat. Is it more cost efficient to just buy a test pipe with my stock itr header or actually spend a few hundred bucks for the hytech header??
ATM the motor has no work done to it. Just intake and a cat back
Re: Hytech header on b18c question.
its up to you really.
also keep the cat. you will not like the noise its going to make. test pipes aren't worth the cost or damage. get a high flow cat if its that big of an issue.
a test pipe and stock header will do nothing.
get one thats at least 500+ and you'll be satisfied.
The thing with the hytech header is that it eleminates the cat.. Basically making it a straight pipe. I'm asking if there would b much of a difference or cost efficient to spend the money for them or just get a test pipe bcuz it's more or less the same
its not more or less the same. and do not get a test pipe.
you move the cat back farther it doesn't eliminate it.
don't buy anything until you actually know what your doing.
