ITR Strut bar VS. Strut bar that bolts to shock studs?
Guys,
I have an ITR strut bar ready to go in. My Hatch even came with the holes pre-drilled, so it's a plug and play deal. As you know, these holes are on the front strut towers, but are NOT directly connected to the front shocks (from a structural standpoint).
I was wondering how much of a difference would an aftermarket strut bar that uses the shocks' studs offer.
Is it worth it to get one of those or should I just install the ITR one?
Thanks,
-Walter
Thanks,
-Walter
Re: ITR Strut bar VS. Strut bar that bolts to shock studs?
^^ I have heard people say that in the past as well.
But, sence you already have it, why not use it, and find out first hand if it makes a difference?
-Walter
Thanks for the insight. It's good to know from someone that has tried both.
You're a funny guy.
-Walter
-Walter
The difference is minimal. Strut bars stiffen by bracing the entire strut mount area/wheel well against the opposite side. In some other cars (I've not seen this in Hondas yet) you can see the effect of this type of flexing as the entire strut mount area pulls inboard, off from the fender.
-A
-A
Ek Forever y0!
There are notions that the neuspeed front strut bar is one of the only ones that behaves in a desirable manner.
They're also cheap!!!
use the itr bar. free, easy to install, and looks decent.
i'm using a gsr bar, and have no complaints...
Ek Forever y0!
They are I believe. I've seen many stores with them.
http://www.summitracing.com/parts/NEU-35-20-70/
For what it's worth, I've heard that the PWJDM 3-point bar is the best, albeit expensive.
Ek Forever y0!
http://www.velocityshop.com/product/...tegra_225.html
Check out the Benen Tripod Bar. I picked one up for $80 locally, although normally a used price might be in the $120 range.
NRG makes a 3 point bar that looks very much like the PWJDM bar for about $150
this is one of those things you should REALLY consider buying used. Save a lot of money.
This is great info guys, thanks for all the options.
I'll start with the ITR bar and move onto a nice 3-point like the NRG or PJDM.
-Walter
-Walter
dohcdelsol
06-01-2004 06:06 PM
