GSR Swapped EK Intake/Sensor?
Okay 2 quick questions....
1) What Intake Should I pick up if I got a GSR Swapped 99 Hatch with a Skunk2 Intake Manifold? Do I get one for the 99 EX Coupe?
2) I have a Chipped P72 with P73 Base mapped....Because I have the Skunk2 Intake Manifold with a SI intake Arm and ITR Box... With that said, When Picking up an Intake system... I noticed on the current Intake I have 2 holes. One for the IAT and the Other one which I think is called the Crank Case Vent tube? NOW, with that said Can I disconnect the IAT Sensor? Is it even being used?
Yes they are currently plugged in.
Re: GSR Swapped EK Intake/Sensor?
Hmm... I'm going to go out and Double Check the Intake Mani for the sensor on the Runner.... I dunno if it helps but it's a 99 DX with OBD1 GSR.
Update: Yes there is a plug connect on the manifold on runner 2. So does that mean the one that ons connected to the intake tube is not is use and can be disconnected?
