Z6 Y7 Mini me timing problems. NO START
Old 02-22-2011, 10:50 AM
PardonmyEK9's Avatar
Icon3 MINI ME Z6 Head on Y7 block
i have a 96 hatch (obd2a)
-y7 block
-z6 head
-y8 intake mani and TB
-y8 tranny
-0BD2a to 0bd1 conversion harness
-p28 ECU
-z6 dizzy
Now i am confused on the dizzy part.. do i use a z6 with a wire conveter or splice or whatever?!?!
Or do i use the y7 guts in the z6 casing???
so confused!!!! i have heard to much different solutions.
If you guys had any problems witht the swap lemme know.
pictures would be great of ANYTHING thats helpfull atleast lol
PLEASE HELP
Old 03-03-2011, 08:12 AM
Default Re: MINI ME Z6 Head on Y7 block
someone has got to know
Old 03-03-2011, 08:16 AM
Seagull Management
94EG8's Avatar
You can do either, personally I like the Y7 guts in the Z6 case better, it's free and it looks cleaner. Make sure you keep the Z6 shaft/bearing assembly, just swap the electronic stuff. Btw, if you put the other Y7 distributor together with the Z6 guts it's identical to a D15B7/D15B8 distributor if you want to know what it fits if you were planning to sell it.
Old 03-03-2011, 09:42 AM
thecruzs2007@yahoo.com's Avatar
why not just get a obd2-obd1 jumper harness??
Old 03-06-2011, 11:49 AM
Do i have to do any re wiring because of the obd2 and obd1 difference if i put the y7 guts in the z6 case?
Old 03-06-2011, 11:50 AM
And what about notching the ears on the y7 dizzy does that work or is just a waste of time?
Old 03-07-2011, 07:09 AM
Come on GURUS. Need my car so i can get a job
Old 03-07-2011, 07:12 AM
Any wire diagrams?!
Old 03-07-2011, 07:13 AM
speedooo's Avatar
The only SOHC distrobutor with a different bolt pattern for the distributor is the P08 head (92-95 vtec head). D15b2/7/8, D16y5/7/8, d16a1, etc... all have the same bolt pattern....
That being said, you can:
A. Buy an Obd1-Obd2a conversion harness
B. Swap guts
C. Unpin and repin the plugs
D. Cut/Solder
Old 03-07-2011, 07:17 AM
Seagull Management
94EG8's Avatar
No, that's the whole point of swapping the guts.
You really can't set the timing properly, plus it looks really ghetto.
Old 03-07-2011, 07:43 AM
Where can i purchase a conversion harness?
Old 03-07-2011, 08:26 AM
Default What are some of the MAIN problems everyone has with MINI ME swaps
Like the title says what are some of the main mini me problems that come after it gets running. Lets hear some storys and info!!!!!
Old 03-07-2011, 09:07 AM
I'm not Rick!
rick_rabies's Avatar
Default Re: What are some of the MAIN problems everyone has with MINI ME swaps
most people dont chip the ecu and tune it since compression has changed.
most people dont get timing jus right and bend valves.
people dont replace the timing belt and other small gaskets and spit oil everwhere
Old 03-07-2011, 09:12 AM
Seagull Management
94EG8's Avatar
Pretty sure rywire sells them.
Old 03-07-2011, 10:17 AM
The Grumpiest
grumblemarc's Avatar
Most people that seem to have an issue seem to be trying to Frankenstein parts together that aren't supposed to be simply because they got them cheap or free. There are dozens of write ups to use as a blueprint but some people chose to go their own route/deviate from the write ups and get stuck/have problems. The write ups I've read are pretty straight forward so stick with what works.
Old 03-07-2011, 10:19 AM
nice i heard most people mini me swaps have little to no power and run like s&!t. why do you think that is???
Old 03-07-2011, 10:20 AM
Lets get those links to the write ups!!!!
Old 03-07-2011, 10:21 AM
first i think i am going to check the local junk yard for a z6 dizzy then if not go to ry wire. is swapping the guts pretty straight foward?
Old 03-07-2011, 10:25 AM
The Grumpiest
There's a search function next to the Quick Links in the gray bar for all of H-T and Google for all of the internet.
Old 03-07-2011, 10:32 AM
speedooo's Avatar
Yes it's pretty straight forward but the screws are pretty easy to strip so be weary.
Old 03-07-2011, 12:44 PM
ok thanks for the heads up!
Old 03-07-2011, 12:46 PM
HA true true. just figured you said youve read em so you can find them quicker. gotta help to get help sometimes
Old 03-07-2011, 12:56 PM
I'm not Rick!
^theres actualy a few stickies here you can look up
Old 03-07-2011, 07:30 PM
ddd4114's Avatar
I'll second the ECU/tuning one. Even after tuning my car (b7/z6 mini-me), I can't run anything less than 89 octane or it'll ping too much.
As far as the "most people mini me swaps have little to no power and run like s&!t" thing goes, "most people" are clueless and don't do the swaps properly. If you do everything correctly, you should have no problems. I've been daily driving mine for about 5 years now.
Old 03-07-2011, 07:50 PM
fonkernuckle's Avatar
^yeah true,friend has a y8 head IM and d16a6 mini-me untuned, p28(runs premium fuel-a must) loves it and people think he's got a B16 under his hood, and yeah daily driver for the last 2 years,only time it ran like schiza was when the pcv hose from IM going to the breather box broke in half.
Quick Reply: Z6 Y7 Mini me timing problems. NO START
