which ecu on jdmb16
Old 02-21-2011, 11:27 AM
luispequeno's Avatar
Default which ecu on jdmb16
i have a jdm b16 from hmotorsonline.com
i have done the bypass for the ckf sensor and it starts up. it always throws a code6 no matter what.
i've read and been told that it may be due to my ecu being bad or i may need to convert.
i have the stock em1 obd2b harness in it now and looking to run a p28 or p30. should I go this route? I would prefer this to fix my cel and get my motor out of limp mode, but I would like to run my p2t for emissions purposes (once a yr).
also, i am running obd2 injectors, obd2 distributor, but the jdm oil pump.
please, please help!!
Old 02-25-2011, 12:39 PM
Default Re: which ecu on jdmb16
bump... any inputs?
Old 02-25-2011, 12:42 PM
The Grumpiest
grumblemarc's Avatar
Why are you bypassing sensors?
Old 02-25-2011, 05:39 PM
Seagull Management
94EG8's Avatar
JDM OBD2 engines don't have a CKF sensor (and adding one requires buying a USDM OBD2 oil pump, CKF sensor and lower timing belt cover) so it's not that cheap to add in. Most guys just tap into the CYP sensor in the distributor to fool the ECU into the thinking the CKF sensor is there.
Old 02-26-2011, 05:06 AM
The Grumpiest
Jeez. How do you keep all this straight in your head?
Old 02-26-2011, 05:44 AM
Seagull Management
94EG8's Avatar
I dunno, I just do.
Btw OP code 6 is for the coolant temp sensor. Which has nothing to do with the CKF trick and both OBD1 and OBD2 ECUs will look for it (2 wire sensor under the distributor) check that out and see if it's bad.
Old 02-26-2011, 08:27 AM
EFPhilly's Avatar
I personally would recommended the p30 (but I use it on S300)
Old 02-26-2011, 08:39 AM
Red_Army's Avatar
p30. its the one for a b16a so use it.
why don't you just get an obd1 harness seems the much easier and cheaper route.
Old 02-26-2011, 09:32 AM
numberone's Avatar
P30
Old 02-26-2011, 10:48 AM
Seagull Management
94EG8's Avatar
You guys seem to be forgetting that simply running an OBD1 ECU isn't going to fix the problem at all. OP will still have the very same issue with an OBD1 ECU, unless the ECU is chipped to disable it. Chances are the sensor is bad (they're cheap, you can grab one from just about any D or B-series engine (and probably F/H-series as well) or there's a wiring issue.
Old 02-26-2011, 12:12 PM
-__-'s Avatar
^^he's talking about the temp sensor. and yeah i did the CKP trick on my harness too works great lol.
as far as which ecu, in any situation: USE THE CORRECT ECU for the engine. unless of course you have modified it fairly heavy (cams etc.) then u want to get it tuned.
Old 02-26-2011, 12:18 PM
tlarimer's Avatar
This, plus you will need a ecu step down to run the P30 OBD1 ecu in your OBD2 car. So you will still need to do this to be able to run your OBD2 ECU once a yr for your emission's testing.
Old 02-28-2011, 11:59 AM
thanks guys, i bought an obd2b-obd1 jumper harness and about to purchase a p30 (the jdm b16).
even more fortunate, its chipped already. i will be buying ectune, to practice on mine and more futuristically tune in my town for cheap
Old 03-08-2011, 11:46 AM
i plugged in a p30 and i'm still showing CEL. when i test the red/white wire, it was showing 3.6v, which i belive should be around 5v. anyone have a clue why its not pushing all 5?
and also, what does the other wire do? what should that one be showing? or does it just pulsate a signal back to the ecm?
Old 03-08-2011, 06:04 PM
any good help out there to give a try?
Old 03-10-2011, 01:49 PM
any wiring gurus? random inputs?
Old 03-12-2011, 09:44 AM
EFPhilly's Avatar
are you talking about the temp sensor red/white wire
Old 03-14-2011, 06:24 PM
yes, last time i checked it.. it was running about 3.6v, when it should be a 5v wire. then i checked it at the ecm and same numbers.. i now have a p30 but i havent had a chance to see how much voltage is running
turbo97coupe
03-31-2009 07:44 PM
street_ride14
03-02-2009 09:17 AM
JerKeK9
09-27-2005 01:52 AM
DarkBB4
03-27-2005 09:56 AM
boostedcrx
10-17-2002 05:03 PM
Quick Reply: which ecu on jdmb16
