Door lock actuators
Door lock actuators
My civic's door locks dont work most of the time with the switch and I think I need to replace the actuators. So I thought instead of replacing them with the OE actuators, I thought of these, what do you guys think? Would they work maybe? Civic is an lx 2000.
http://www.ebay.com/itm/Wireless-Rem...37a916&vxp=mtr
You're better off using OEM parts.
It's unlikely that both are bad. Is this issue both or a particular side? Something else might be wrong/broken besides the motor.
Posted from Honda-tech.com App for Android
Re: Door lock actuators
My ebay actuator died in 6 months.
but yes, they will work. It just take a bit more work to install them. Which really isn't that hard.
It costs more, but DEI is a much better choice.
Well I'm guessing its the actual actuators because the locks/doors are hard as hell to open manually much less opening with the switch, every now and then the switch will open all 4 doors but its more likely they wont. I just wanted to use these to open them with a remote to open the door for my girl before she goes in
Are the doors difficult to lock/unlock from both the inside and outside?
Grab the DEIs and throw a cheap alarm in there while you're at it if you don't have one already.
The back doors are hard to open. The lock **** is hard to pull from the inside and the handle from the outside, as if there was glue in it to stop it from opening
b20acura
25
02-11-2012 04:45 AM
