Stalling Out at Idle, Gutless
I just finished swapping in a ls into my ej1, its a stock ls on 14psi. When i do a cold start it idles and runs fine, after about 3-5min it begins to idle rough and stall out. If I give it gas it does not stall and runs great above 1000rpms. My fuel pump is fine, replace dizzy, and all my grounds are hooked up. I don't think i have a vacuum leak. I plugged in all the wires in the right spot and it is not throwing any codes. I tried to drive it and it is gutless and just stalls out even when i floor it.
Any ideas what it could be?
The Grumpiest
Re: Stalling Out at Idle, Gutless
Total lack of info for a turbocharged car with issues.
Basemapped or tuned? MAP sensor stock? Describe FULL setup and not just "14PSI" because that doesn't tell us squat.
I will check the timing again.
It is a chipped p75 Tuned on crome pro. Im using a walbro 255, 450 Dsm injectors, GM 3 bar map sensor, New inline fuel filter, Turbonetics T3/T4, Precision 39mm wastegate, Ramhorn, 3in DP, rebuilt stock ls.
VTgringo
05-19-2003 08:03 PM
