HELP!! H22 SHIFT LINKAGE IN EK
Ok so my ek 4 door is swapped with an h22 and im going to get rid of it and swap in the d16y8 single cam in it... now i know the shifter area was cut out a bigger piece to make the h22 shift linkage fit and everything.... now my question is, should the single cam shift linkage be able to bolt back up and function the same ??? if not what would i have to do?? thanks
The Grumpiest
Re: HELP!! H22 SHIFT LINKAGE IN EK
Stop reposting the same question.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/h22-single-cam-question-3113979/
Try the Hybrid section.
The Grumpiest
So you're asking if there will be an issue if you DON'T repair the mods made to get the H22 in there in the first place? You ask for solutions and then reject them but you know it's what you have to do?
So you're looking to half-*** it? Solution:Try it yourself and find out.
Championship
10-18-2011 10:20 PM
