Dead no spark cx
Dead no spark cx
94 cx stock. pulled out Of driveway and dead. No spark. Cranks cel illuminates and turns off as it should. I hear the fuel pump prime. I have a full tank. I pulled the dizzy it's cold out here. What should it, what terminals and what should my readings be? I also got a spare dizzy from the junkyard. I can't push it into the garage so I want to check the old and new dizzy inside.
Re: Dead no spark cx
Here is coil spec:
Primary Winding Resistance (A and B terminal) = 0.6-0.8 Ohm (you right)
Secondary Winding Resistance (A and Spring) = 12.8-19.2 kOhm (you right)
Both coils are within spec how do I bench test the rest?
No one knowS how to bench test the igniter? I don't Luke just blindly throwing parts at a car. I like to truly diagnose the problem. Any help would be great here.
Yes I read the FAQ but there is mo listing for a bench test of the ignitor also there isn't one in the fsm. I put a dizzy in and it runs. I just want to know what part was bad.
cydinthegreat
15
08-24-2011 03:55 PM
Honda Sport
14
11-15-2004 04:37 PM
