Car jerks when I let off the gas
Old 01-08-2013, 06:17 AM
Joeysalois's Avatar
Default Car jerks when I let off the gas
I have a ls swap (b18b1) in my 99 lx
My problem is that whenever I let go of the gas the car will jerk. None of my friends cars do this. It mostly happens in higher gears like 4-5 but sometimes happens in 3rd. Also happens in 1st and 2nd a decent amount of times. What could this be is it my car or is it my driving cuz I just started driving stick.
Old 01-08-2013, 06:28 AM
Call me Cheeks
Mr Ohms's Avatar
Default Re: Car jerks when I let off the gas
It could be your driving habits since you're learning to drive a stick.
Could also be a bad motor mount.
Old 01-08-2013, 06:45 AM
kyden's Avatar
motor mounts good?
Old 01-08-2013, 08:52 PM
redtherocket's Avatar
Sounds like your fuel cut isn't working properly...
When you let off the gas, the TPS tells the ECU that the throttle is close...
The VSS tell the ECU the car is still moving...
Fuel is cut from the engine on decel until the engine is revving less than 1500 rpm when it comes back into play...
Just a thought...
Old 01-09-2013, 01:20 AM
Technical Hero
HondaPartsHero's Avatar
Check your ignition timing as well if you haven't.
Old 01-09-2013, 03:46 AM
gzes's Avatar
My guess is motor mounts. Whej i pulled the engine from my sol damn theh were done... Bet when i pull the engime from my black sol they are also done thats why i ordered new ones. Id look into that soon
Old 01-09-2013, 06:16 AM
strategy400's Avatar
How are the torque stops or are they even installed with the swap?
EGlove23
21
01-14-2013 02:13 PM
B18tSOL
03-10-2007 01:10 PM
Jxi8s2k
02-13-2006 02:14 PM
gots_a_sol
08-06-2004 08:03 PM
Y2Phunk
10-22-2003 10:43 PM
Quick Reply: Car jerks when I let off the gas
