civic really low idle
Hi guys, i have a 94 honda civic with a d16z6. When the car is cold it idles at about 1.5k rpms but once it warms up the idle drops down to about 100rpms, this suck because the whole car shakes. I tried adjusting the throttle screw but it wont work and yes i unplugged the iacv before adjusting. I also changed out the iacv and got a new tps sensor there are no vacume leakes either i checked for that. Can any poit out the problem? Thanks
Re: civic really low idle
It sounds like you need to clean out your FITV
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/
sometimes the idle regulator plunger cloggs up its easy to clean and can be found bolted to the inlet manifold i had the same problem and the car also does it after a weeks worth of no usage but settles into proper idle once it has done some miles
I just cleaned the FITV, it wasnt that dirty but i cleaned it anyways. When i put it back the same thing happene,, the idle was still really low. I couldnt find the idle regulator plunger, do you havve any pics of it?
My hatch does the same thing... usually when I start it up first thing in the morning(it idles around 400-600 rpms) but after a couple seconds it idles normal.... cleaning the iacv helped out somewhat ill try cleaning out the fitv next
Follow FSM procedure to adjust your idle speed. There's a how-to in the FAQs sticky. Also, at 100rpm your engine would stall itself out. Stock tachometers are notoriously inaccurate.
I had the same problem and swapped out the iac and still had the same problem that started about a week later ended up having a bad iac and to replace it again
