eG WITH B16a transmission wont engage???
I have a 95 civic hatchback with a b16a swap? For some reason my transmisson isnt engaging when i release the clutch... I still have the same pressure on my clutch as before this happened.... When its in gear and i release the clutch and give it gas the speedometer still moves as if i was driving... i thought it was the pressure plate but now not so sure.... any info would be greatly appreciated?!?!?!?!!?!!?!
Re: eG WITH B16a transmission wont engage???
If the clutch pedal feels the same, and your speedometer is still acting like your car is driving normally, it's either an axle problem or a transmission problem. Check your axles.
i just replaced the axle that was messed up..... it goes in and out of every gear fine doesn't grind or make noises.... could it jus be the diffferential or the pressure plate
If it was the pressure plate, your speedometer wouldn't be reading anything. If it was the diff, same deal. The VSS reads off the transmission - if the tranny isn't spinning, your speedo wouldn't be rolling.
You just replaced the axle, then this problem started? Or did the car work fine afterwards, then this started? I would still double check your axles.
