94 eg hatch si spark plugs wire help
Hi i was trying to replace my sparkplugs in my car 94 civic si hatchback running a mini me swap. The one probalem i have is this. The spark plugs wires wont come out of the head... All of em are on there really well. Cant pull em off. And i was trying to pull em off forcefully and this happened. Any way that they are stuck? Dont know what happened... Bought the car like this. Help please!! Any help/ advise is helpful!!
Re: 94 eg hatch si spark plugs wire help
That won't help, the spark plug tubes touch the top of the valve cover. You won't have access to the sides of the cable. Try spraying some wd40 down the center of the spark plug cable tube with a straw). Then get a pair of needle vice grips to twist and loosen the plastic rubber
The Grumpiest
It was just a suggestion since I've never had to deal with a problem like this. The thought was that even with the boots stuck in the tube you could pull the V/C and get at it from the other side. There's going to be no easy way of doing this. Last time I read of a problem like this the car was overheated to the point that the boots melted to the inside of the valve cover. If that's the case WD-40 is doubtful to work but at this point give it a shot. It's also worthy to mention that the head was warped pretty badly because of the overheating.
Needle nose pliers or vise grips. Twist in a circular motion before you try removing the boot. Dont pinch the boot too tightly because it will just rip farther down. Just enough to get it to turn
Technical Hero
That's pretty typical of a neglected and/or over heated head. Try and like above with some penatrant and pull that plastic portion off with some long needle nose pliers. More than likely the boot that goes around the plug will remain. Use a long flat tip screwdriver and/or a coat hanger to remove it. Keep at it, good luck.
drew_kousk
10-05-2010 01:32 AM
joe.wong321
20
03-05-2008 07:21 PM
timmya
12
05-06-2006 08:18 AM
