2000 Civic LX manual transmission
I have a 2000 LX 4 door sadan with a bad tranny, it's a D16Y7 non Vtec engine with a S40 A000 manual 5 speed tranny.
Question is, if I put a used 5 speed tranny out of a EX which is a S40 B000 I think, will it bolt up and will the speedo work correctly?
I believe it has different gearing.
Any insite on these granny's and interchangeability is greatly appreciated.
Thank
Thank
Re: 2000 Civic LX manual transmission
if its from another 2000 than everything is plug and play and even if its from an earlier civic 92-00 it should work. You might have to change the vss on the 92-95 to the one off of your bad tranny (if anything else if in doubt compare vss's)but should be easy.
I put a '00 auto trans in an 98 civic(did not even have to change the vss) and it works just fine.
JDMBukLau
10
01-16-2014 07:17 PM
dayum itz jee
Acura TL, RL & ZDX
01-03-2008 05:52 PM
