Brakes Locked up, help me please.
Okay, after I get my car back from eric ( for all of you who know the story) The master cylinder was bad, It wouldn't hold pressure.
I bought a refurbished M/C from autozone yesterday, installed, and bled the brakes. they worked fine ALL yesterday, I drove all over town and they worked fine.
When I got in my car today, the car started fine, brakes worked fine. and i started driving, and slowly the brakes started grabbing harder and harder by themselves. Now the pedal feel rock solid when the car is off.
Bad master cylinder?
Re: Brakes Locked up, help me please. (poison)
..nope.
I just went downstairs, and loosened the front hard line on the MC, brake fluid shot out, and i heard the front calipers loosen up.
So it was my MC, but whats wrong with it?
Re: Brakes Locked up, help me please. (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI »</TD></TR><TR><TD CLASS="quote">did you bench bleed the master cylinder before installing it ?
..no i prefer to have 100% air in my master cylinder.
well anyways, in hopes that my master cylinder was still good, i pulled it off, cleaned it up, and put new brake fluid in. i didnt bleed the lines yet, and the car braked just fine for having air in the lines, i was bleed the lines today when my brakes locked up on me AGAIN. pedal was rock solid.
Re: Brakes Locked up, help me please. (JUN EK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN EK9 »</TD></TR><TR><TD CLASS="quote">
okay. im glad your brakes are fucked up. and i hope they stay that way. sarcastic people like you. look at what the thread is, "brakes locked up, <U></U>help me please."
now i cant seem to understand why i even attempted to try and suggest something to you.
loser.
loser.
my friend had a simailar problem with his ford a while back and it turned out that his calipers went and locked up
Just a suggestion
-Brian
Just a suggestion
-Brian
loser.
i agree that was highly rude he was trying to help you
loser.
Re: Brakes Locked up, help me please. (vtec69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec69 »</TD></TR><TR><TD CLASS="quote">my friend had a simailar problem with his ford a while back and it turned out that his calipers went and locked up
Just a suggestion</TD></TR></TABLE>
That or your lines.
Try to be nicer to people that are helping you.
That or your lines.
Re: Brakes Locked up, help me please. (turbogixxer)
I just last week fixed this same problem on my car after having upgraded my brakes to gsr ones. At first I replaced both rear calipers since they where the ones locking up and that didnt help. It turned that the problem was that I was using an ABS brake booster and a non-abs brake booster. On ABS boosters the rod is longer than on non-abs. Make sure that the booster and mc combo you are using are either both abs or non-abs. I pretty sure that could be your problem.
Re: Brakes Locked up, help me please. (93civicsedan)
SORRY SORRY, bad day. Don't get butthurt over sarcasm. its the interweb people.
When I said in my first post "bled the brakes" that included the master cylinder too, sorry i wasnt more clear.
anyways. its not the calipers because they loosen back up when i undo the banjo bolt. I think I might just replace the master cylinder, again. because that seems to be the trouble.
Does anyone know if a bad MC/BB combo could cause this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN EK9 »</TD></TR><TR><TD CLASS="quote">Does anyone know if a bad MC/BB combo could cause this?</TD></TR></TABLE>
calipers and lines usually hold pressure, not MC. Check your lines too.
But it is a autozone product, so anything is possible.
1sikhatch
12-07-2009 04:18 AM
