What do I need when I swap out my B16 in the EG6??
Old 07-27-2004, 09:23 AM
SOHC_DK.'s Avatar
Default What do I need when I swap out my B16 in the EG6??
I have an Eg6 with the B16A2 obd-1 and I just bought a B18C4 (same as your B18C1) it's an OBD2b (I think) I will swap my own injectors, distributor and generator.. that would be all right??
My plan is tyo buy this:
Distribuater ring/washerthing
Oildrain washer
whashers for gearoil??
whashers for fuel lines,
MTF gearoil 75W/90, 2.5 L.
Castrol 5W/40 oil 4 L.(the one I normally use)
washers to the injectors
Some coolant fluid and clean water
*Clutch fluid (how much and what kind??)
Anything else I should think of???
Please help, were dooing this on saturday, so it would be nice to have the right parts ready..
M. Nielsen,,.. Denmark
SOHC_DK. is offline
Old 07-27-2004, 09:37 AM
dantastic's Avatar
as long as the motor is out of the car, i would also replace the timing belt. i usually use 5w30 oil (which im pretty sure is OEM spec). 5w40 is a bit heavier, usually for european cars (ie BMW). i would only use honda MTF or 10w30 motor oil for the tranny.
that obd2 motor will swap in perfectly with the parts and engine harness from your b16a. i would also get an obd1 p72 GSR ecu to run your new motor
dantastic is offline
Old 07-27-2004, 01:00 PM
SOHC_DK.'s Avatar
Default Re: (dantastic)
Ok.. thanks..
the Timing belt was just changed 100 KM. ago, so no need for that..
About the ECU, that'l wait until winter time, right now I will run it on stock ECU, tuned with Hondata S200..
About the oil maybe my memory is wrong, it might be 5W-30 as the manual says...
SOHC_DK. is offline
Old 07-27-2004, 01:51 PM
VvPeachyvV's Avatar
Default Re: (SOHC_DK.)
def replace the water pump, u dun wanna do all that then it goes out only to take out all your hard work.
VvPeachyvV is offline
jesse.pulido
07-03-2013 10:37 PM
cowboys22cardinals22
04-22-2008 04:10 AM
98civic94gsr
01-26-2005 03:48 PM
SOHC_DK.
07-27-2004 07:38 AM
projecthybrid04
12
10-30-2002 03:34 PM
Quick Reply: What do I need when I swap out my B16 in the EG6??
  • Ask a Question
Question Title:
Description:
