whats the difference from these kinds of a/c..
Old 07-26-2004, 11:16 AM
DiSbaDbOi's Avatar
Default whats the difference from these kinds of a/c..
like the topic says...what are the difference between r12 and r134? did searches but no luck...
DiSbaDbOi is offline
Old 07-26-2004, 11:33 AM
DiSbaDbOi's Avatar
Default Re: whats the difference from these kinds of a/c.. (DiSbaDbOi)
anyone...?
Old 07-26-2004, 12:06 PM
RusBear's Avatar
R-12 is the old refrigerant that is not being produced anymore because of environmental issues. Even if you find it, it will be pretty darn expensive. R-134 is the new stuff; it does not cool as effectively, so it requires different A/C equipment. It is possible to retrofit an R-12 system to accept R-134, but, once again, that's gonna cost you somewhere in the neighborhood of $600-800.
Now, last time I was at a car parts store, I saw a recharge kit for around $40 that claims to refill either system. No idea what that's all about, probably just a R-134 tank with fittings that can go to an older system.
RusBear is offline
Old 07-26-2004, 12:20 PM
DiSbaDbOi's Avatar
Default Re: whats the difference from these kinds of a/c.. (RusBear)
well i removed my a/c cause i had a turbo set-up for my car..now i decided not to put it on and sell it..so im planning on putting my turbo back on but i would have to recharge it...which one do i use? r-12 or r134...?
Old 07-26-2004, 12:38 PM
RusBear's Avatar
My car doesn't even have A/C, so I can't really help you there But, I found this page on the "other" forum that tells you how to find out which type you've got: http://www.honda-acura.net/for...46508
Scroll down a bit for the worthwhile replies; somebody said that the switch from R-12 to R134 happened in 1993. Also, I read somewhere that there is stuff you can use instead of R-12 in the older system, called Freeze-12. If you have a newer car, just go with R134 though.
RusBear is offline
Old 07-26-2004, 12:40 PM
DiSbaDbOi's Avatar
oh alright thanks alot..imma check out the site..
slimx
10-13-2014 06:10 PM
Outrun
Audio / Security / Video
06-30-2005 03:14 AM
nate951
10-21-2004 06:30 PM
BrianZ
22
06-29-2004 02:01 PM
SIboi
01-28-2002 04:44 PM
Quick Reply: whats the difference from these kinds of a/c..
  • Ask a Question
Question Title:
Description:
