idle problem.
Old 07-26-2004, 07:49 PM
vtecmike1's Avatar
Default idle problem.
i'm pretty confused. after putting everything back together on my car and starting it up it runs like a champ. idles perfectly when its cold but when the car reaches operating temp the idle goes from about 1000-400 in surges back and forth. i have no cel, checked the vacum lines everything is fine. and if i remove the tps it will idle fine with no surges. but my vafc says the tps voltage is fine so i'm not sure what to do. any suggestions?
vtecmike1 is offline
Old 07-26-2004, 07:53 PM
FERIOkid's Avatar
Default Re: idle problem. (vtecmike1)
can you adjust your tps? I know on my d15b it was adjustable and i had to take my stock d15b7 throttle body and it worked fine. Make sure all your sensors on your throttle body are correct, a lot of them are the same. Thank for instance your idle air control valve could be swapped with something
FERIOkid is offline
Old 07-26-2004, 07:59 PM
vtecmike1's Avatar
Default Re: idle problem. (slowdx9585)
its not adjustable on the b16 without a dremel and i dunno if i'm man enough to try that. but the vafc says the voltage is ok so i dunno what i would need to adjust it to. i could try to clean the sensors out i guess. i'm just pissed cuz i wanted to get it dynoed soon and i can't really do that without figuring this idle thing out.
Old 07-26-2004, 08:50 PM
AftermarketCarl's Avatar
I had the same problem a couple of years ago. I don't recall exactly what it was called so I'll describe it to you. Underneath my GSR throttle body is some kind of thermal valve. I fixed my idle problem by replacing it with one my friend's extras. When I took apart my original part i found out that the internal valve had un-threaded itself and I was actually able to re-thread it. Just to make sure that it worked properly I reinstalled it and I haven't had any problems since. Good luck.
AftermarketCarl is offline
Old 07-28-2004, 07:26 AM
vtecmike1's Avatar
Default Re: idle problem. (yelointeg)
that wouldn't be the iac would it. because on the b16 its located on the intake manifold and it has an allen head adjuster bolt. i'm also thinking i might need to turn up my idle screw a little due to all the extra air flowing in after the head work and cams, since i'm not flowing anymore fuel. sean down at church said i could get it tuned with the bad idle and it wouldn't effect anything so maybe after he adjusts the air fuel ratio's and fuel pressure that could help the idle.
Old 07-30-2004, 02:20 PM
vtecmike1's Avatar
update:
carlo came over, took him 30 seconds to make me look like a moron and he fixed my car. with the iat disconnected and a few vafc tweaks of fuel at idle the car runs like a champ and i'm ready for tunning. i should have a dyno graph for all you patient people in about a week or so. so stay tunned, finnaly after about a year of building my little b16 n/a monster will be complete.
TegraD
05-15-2009 02:55 PM
b16a3delsol
08-15-2007 09:29 AM
caLiH22A
08-24-2004 08:05 PM
V-Thang
Acura TL, RL & ZDX
02-24-2004 02:10 PM
GreenR
09-07-2002 08:50 AM
Quick Reply: idle problem.
  • Ask a Question
Question Title:
Description:
