So I traded my crx for a del sol...
Old 07-27-2004, 07:47 AM
UNDER PRESSURE's Avatar
Default So I traded my crx for a del sol...
I traded my crx for a del sol, and everything under the hood seems to be working properly except I noticed that vtec engages @ 4500rpm. Is this right? The engine in the car is a Jspec B16A running a P28 ecu, I don'k know if it's chipped or not but from my understanding I has to be chipped or I will get detonation, correct? Any help will be appreciated TIA.
UNDER PRESSURE is offline
Old 07-27-2004, 08:01 AM
Default Re: So I traded my crx for a del sol... (HTechBB)
Good looking out bro.
Old 07-27-2004, 08:36 AM
Happyman's Avatar
Default Re: So I traded my crx for a del sol... (UNDER PRESSURE)
Just open the ecu and look. My buddy who put a jdm b16a in his del sol got a skunk2 chipped p28 with the swap.
Happyman is offline
Old 07-27-2004, 09:12 AM
Default Re: So I traded my crx for a del sol... (Happyman)
How do I know if it's chipped though?
Old 07-27-2004, 09:13 AM
Happyman's Avatar
My friends said Skunk on the chip...
Happyman is offline
Old 07-27-2004, 09:16 AM
boostin4door's Avatar
some chips actually say the specs on them... i know mine does, but i guess if the car runs good, i wouldnt worry... just try to pop the ecu open and look for a diff.
boostin4door is offline
Old 07-27-2004, 09:17 AM
sheepey's Avatar
they all dont say bro.... i got a skunk2 p28 and it doesnt say it on mine....u have a rev limiter???and if so what does it go to?
sheepey is offline
Old 07-27-2004, 09:27 AM
Default Re: (sheepeg3)
The rev limiter is at 8200rpm...
Old 07-27-2004, 09:28 AM
sheepey's Avatar
hmmm i dunno then...cuase mine doesnt have a rev limiter... but try openin it up maybe there will be a tag GL
sheepey is offline
Old 07-27-2004, 09:29 AM
photec2's Avatar
Default Re: (UNDER PRESSURE)
are you looking at the stock tach?? they aren't very accurate
photec2 is offline
Old 07-27-2004, 09:35 AM
Default Re: (photec2)
That's also one of my problems the tach doesn't keep up with the actual engine rpm and the speedo jumps around.
Old 07-27-2004, 09:36 AM
Happyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by photec2 &raquo;</TD></TR><TR><TD CLASS="quote">are you looking at the stock tach?? they aren't very accurate</TD></TR></TABLE>
Most stock tachs will only be off by a few hundred if that. 4500-5300 would be a pretty big offset.
Happyman is offline
sheepey's Avatar
thats why u need to buy my Apex RSM off me! it reads GREAT!
sheepey is offline
Old 07-27-2004, 09:48 AM
Any other suggestions?...
Old 07-27-2004, 09:56 AM
Del Sol SiR's Avatar
switch back to a stock P30
Modified by DelSolSiR at 11:52 AM 7/27/2004
Del Sol SiR is offline
Old 07-27-2004, 09:59 AM
Default Re: (DelSolSiR)
What's the difference?
Old 07-27-2004, 10:53 AM
p30 is what came stock with the del sol 94-95 vtec model in the US.
Modified by DelSolSiR at 1:39 PM 7/27/2004
Old 07-27-2004, 10:54 AM
OIC.
Old 07-27-2004, 01:23 PM
nimblecivic's Avatar
I ran a p28 in my 93 EX w/b16a and I had detonation like a maffaq'r...switched over to a p30 and it runs a helluva lot better...no chip whatsoever....
nimblecivic is offline
Old 07-27-2004, 02:18 PM
Default Re: (nimblecivic)
Kool good looking out bro.
Old 07-28-2004, 08:52 AM
O.K. I opened up the ecu and I could not tell if it was chipped or not. On the cover of the ecu it said '95 gsr in red marker.
Old 07-28-2004, 09:13 AM
jArceo's Avatar
thats ur problem. gsr's have dual stage intake manifold so VTEC engages at 4500 and the secondary butterflies open at 5400 i believe
get a p30 or chip ur gsr ecu
jArceo is offline
Old 07-28-2004, 09:28 AM
Default Re: (xFlipNotiKx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xFlipNotiKx &raquo;</TD></TR><TR><TD CLASS="quote">thats ur problem. gsr's have dual stage intake manifold so VTEC engages at 4500 and the secondary butterflies open at 5400 i believe
get a p30 or chip ur gsr ecu</TD></TR></TABLE>
Werd
Old 07-28-2004, 09:34 AM
Default Re: (widebodyjaeg16b)
Kool good lookin out. So I will have no detonation by driving w/ this ecu right? And if I chip the ecu or get a P30 my car will run better correct?
Old 07-28-2004, 09:37 AM
hatchbackhonda's Avatar
the only thing is there is a couple diff skunk2 programs like for insistance mine vtec engages at 5800 and there is no red line . i bought my computer from skunk2 though i dont know if that makes a differance or not
hatchbackhonda is offline
Quick Reply: So I traded my crx for a del sol...
  • Ask a Question
Question Title:
Description:
