how do u take the o2 sensor out?!?!
Old 07-26-2004, 04:09 PM
simplypinoyy's Avatar
Default how do u take the o2 sensor out?!?!
Im trying to use my stock o2 sensor on my dc sport header but i cant even get the o2 sensor off the damn exhaust manifold. How do u guys get it out?
simplypinoyy is offline
Old 07-26-2004, 04:10 PM
zad5's Avatar
they make a special socket or a 7/8 wrench i believe i forget the umm metric size. just get a pipe around the 7/8 wrench as a braker bar and get a friend to step on the header while u loosen teh son of the biyaach.
zad5 is offline
Old 07-26-2004, 04:12 PM
Electrician
Deemeetree's Avatar
Go to your local auto parts store and get an O2 socket. Looks like this:
Deemeetree is offline
Old 07-26-2004, 04:14 PM
ABK
ABK's Avatar
Default Re: (Dimi)
yeah you need a breaker bar and the o2 socket. IT would be the best if the header was back on the engine.
ABK is offline
Old 07-26-2004, 05:28 PM
hondasport2000's Avatar
I just used a big *** monkey wrench.
hondasport2000 is offline
Old 07-26-2004, 05:36 PM
Default Re: (hondasport2000)
i always used a wrench.. so does my little sister.. but yea the socket.. got that a little while back.. good tool
menkio is offline
Old 07-26-2004, 06:00 PM
eg crunkmonster's Avatar
Default Re: (DewMota)
dont forget the wd40 and maybe a torch
eg crunkmonster is offline
Old 07-26-2004, 06:01 PM
ABK
ABK's Avatar
Default Re: (eg cookiemonster)
oh yeah it help to heat up the exhaust pretty good, if you can't get it off.
ABK is offline
Old 07-26-2004, 06:07 PM
Quick99Si's Avatar
Default Re: (ABK)
If it's not glowing orange, you're only making it harder for yourself
Adi
Quick99Si is offline
Old 07-26-2004, 06:09 PM
Slow98sedan's Avatar
Hey man.
Just goto the local auto parts store and get a O2 Socket. Its like 7/8s. I got mine for $5. No need for a breaker bar,I got mine loose no problem. If you can,put it back on the car..let the car run for like 2-3 minns...long enough to get the mani warm to "loosen" up the sensor,slip the socket on and it'll come loose. Pretty easy. Dont forget to put some antiseeze on the new one
..adam..
Slow98sedan is offline
ABK
ABK's Avatar
Default Re: (Quick99Si)
lol you don't have to go that far
ABK is offline
Old 07-26-2004, 06:31 PM
civicmon's Avatar
Do it when it's warm.. also spray a lot of bolt loosener and let it soak in there for a little bit. I did it but it took a LOT of leverage to get it to move but it finally did.
MUCH easier to do it on the car btw.
civicmon is offline
Old 07-26-2004, 07:13 PM
thanks a lot you guys. I figured it was the 7/8 and I was like on top of my engine bay yankin on that **** and all my engine did was gettin pulled up along w. the bolt. I'll try to get that socket thanks!
Old 07-26-2004, 07:29 PM
theres a thing called liquid wrench, it works like wd-40 , but its purpose is to make it easier to take bolts off, i use it on areas where the bolt has been exposed to lots of heat, such as exaust systems, you could get it at your local kregen, or hardware store
b18cpowered is offline
Old 07-26-2004, 07:50 PM
FERIOkid's Avatar
Default Re: (b18cpowered)
mine came off with a 7/8 wrench no problem
FERIOkid is offline
crazy eyez killa
12-09-2004 03:14 PM
icon_race_eg
14
05-05-2004 05:49 PM
Sherm
05-19-2003 09:38 PM
Sir_Phobos
02-15-2003 10:55 AM
StyleTEG
07-05-2002 10:28 PM
Quick Reply: how do u take the o2 sensor out?!?!
  • Ask a Question
Question Title:
Description:
