Difference between code 1 and 41
Old Jul 27, 2004 | 12:37 PM
Phatch99's Avatar
Default Difference between code 1 and 41
Like the topic says........
Old Jul 27, 2004 | 01:58 PM
MNEJ1GUY's Avatar
Default Re: Difference between code 1 and 41 (Phatch99)
I need to know too....Mine came on for awhile and it's off now...
Old Jul 28, 2004 | 05:51 AM
Phatch99's Avatar
Default Re: Difference between code 1 and 41 (MNEJ1GUY)
bump..... for someone to help....
Old Jul 28, 2004 | 05:52 AM
Phatch99's Avatar
bump for some help!!!
Old Jul 28, 2004 | 06:02 AM
ProJectCvic's Avatar
it's code 1 a malfuction of the 02 sensor itself and code 41 a malfunction fo the o2 senor heater wires?
Thank my thought on it
Old Jul 28, 2004 | 06:32 AM
Phatch99's Avatar
Default Re: Difference between code 1 and 41 (ProJectCvic)
i have code 41.. so how do i fix the wires? car: lsvtec stock 99 h/b with conversion harness to obd1 p72 ecu, if that helps...
Old Jul 28, 2004 | 08:59 AM
Phatch99's Avatar
bump
Old Jul 28, 2004 | 09:34 AM
im throwing a 41 too. I m trying to rewire it. If that does work, i will replace it. I'll tell you how it goes in a couple days.
Old Jul 28, 2004 | 09:43 AM
Phatch99's Avatar
i even swapped out a different o2 and its still throwing the same code. does it matter if obd1 or obd2 o2 sensor?
Old Jul 28, 2004 | 09:54 AM
Relic1's Avatar
the GSR uses positive voltage from the ECU to run the O2heater and the other side of the heater is grounded.
Pretty much every other h/a (from what I've seen) has the ECU grounding the heater to make it active and of course the other side of the heater is tied to power.
Old Jul 28, 2004 | 09:55 AM
Phatch99's Avatar
Default Re: Difference between code 1 and 41 (Relic1)
so does this mean my ecu is bad?
Old Jul 28, 2004 | 09:59 AM
EE_Chris's Avatar
There is only so much you can check here and you need a Helms and multimeter to do it.
You've got the O2 heater section + 2 wires + the ECU.
First make sure the heater section isn't blown out - 15-40 ohms is spec.
Make sure your wires aren't open or shorted out.
One black wire is fed battery voltage - the other wire goes to the ECU. Check to see if there is battery voltage on one wire - check to make sure the other black wire is going to the correct spot on the ECU/jumper harness.
If the O2 checks out and the wiring looks good - substitute an ECU. Yes, the heater control circuitry inside the ECU can foul up.
EDIT: OH - didn't know that about the GS-R and its O2 heater control strategy- my Civic uses the above strategy (supplied +12v with ECU controlling the ground).
Old Jul 30, 2004 | 12:20 PM
Relic1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phatch99 &raquo;</TD></TR><TR><TD CLASS="quote">so does this mean my ecu is bad?</TD></TR></TABLE>
no, only that your O2 is probibly wired wrong.
Old Jul 30, 2004 | 12:54 PM
JoeCDN's Avatar
im gettin the saame codes but im also get code 6...WHat do you guys think is my problem? And wha tis the o2 heater??
Old Jul 30, 2004 | 02:55 PM
EGSSdreamer's Avatar
Default Re: (JoeCND)
&gt;&gt;&gt;And wha tis the o2 heater??&lt;&lt;&lt;
Honda O2 sensors have 4 wires, the heater wire helps to heat the sensor up more quickly when you first start the engine. This wire will carry much higher power than the actual sensing wire which has to be extremely sensitive to small changes in voltages. The hardest part most of the time is figuring out which wire is which... and also which pin it hooks up to in the harness if you're doing the wiring yourself.
I don't claim to be an expert in any more than just plain definitions. Hope it helps.
89 civic si
10
Oct 10, 2006 01:07 PM
ilikehonda
Sep 30, 2005 03:52 PM
Endoe
Dec 30, 2004 01:35 AM
Hondasaurs
Apr 25, 2003 02:19 PM
