How to Check if the Civic is having LSD Gearbox???
Old 07-25-2004, 11:51 PM
stingie's Avatar
Default How to Check if the Civic is having LSD Gearbox???
Hi, I've gone through a car advertisment saying that this particular 96 JDM-EK4 comes with a LSD Gearbox. Is there any quick method to confirm it without taking the whole tranny apart?
stingie is offline
Old 07-25-2004, 11:59 PM
Default Re: How to Check if the Civic is having LSD Gearbox??? (stingie)
youll be able to see straight through the diff. if its not lsd youll see a bar going through it
drunknbass is offline
Old 07-26-2004, 12:34 AM
TSPeed Factory
AzntaggeR's Avatar
Default Re: How to Check if the Civic is having LSD Gearbox??? (drunknbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drunknbass &raquo;</TD></TR><TR><TD CLASS="quote">youll be able to see straight through the diff. if its not lsd youll see a bar going through it</TD></TR></TABLE>
100% way to know is to pull out an axle.
AzntaggeR is offline
Old 07-26-2004, 01:36 AM
dh
dh's Avatar
Jack it up, and spin one of the wheels. If the wheel on the other side spins also, the it has LSD.
dh is offline
Old 07-26-2004, 01:42 AM
stingie's Avatar
Default Re: How to Check if the Civic is having LSD Gearbox??? (EKallmotor)
Thanks for the help. Will there be some LSD wordings on the tranny and how to i determine what part number it is from?
stingie is offline
Old 07-26-2004, 01:59 AM
jdmsiR20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">LSD type (courtesy of Ninety2SiR)
If you can NOT look thru it, then you do not have LSD.
courtesy of https://honda-tech.com/zerothread?id=642479
jdmsiR20 is offline
Old 07-26-2004, 02:05 AM
stingie's Avatar
Default Re: How to Check if the Civic is having LSD Gearbox??? (jdmsiR20)
WOW, OMG, that means I need to take the axles apart to confirm it. I m just concerned that the guy wouldn't let me do it. I wouldn't let someone jack my car up, tear the axles apart just to see the LSD
How about markings on the gearbox? I've browse the net and so far I've only found marking for the Y1 Tranny. Is there any markings for the 96 B16A LSD gearbox somewhere on the tranny?
stingie is offline
Old 07-26-2004, 02:46 AM
lol.. taking your axles off takes 15 mins... not even.. take off wheels/jack/fluid.. remove lca castle nut on bolth sides, pop out axles... done...
menkio is offline
Old 07-26-2004, 03:07 AM
stingie's Avatar
Default Re: How to Check if the Civic is having LSD Gearbox??? (DewMota)
Whoops.. Looks like i m pretty noob at this. Any step by step guide anywhere?
stingie is offline
Old 07-26-2004, 05:13 AM
SlepT ej6's Avatar
i dont know about you guys but i wouldnt let someone take out my axles jsut to check to see if i have lsd, id rather do a burnoutto show him or let him jack up the car and spin the wheels...
SlepT ej6 is offline
Old 07-26-2004, 05:14 AM
kommon_sense's Avatar
Default Re: How to Check if the Civic is having LSD Gearbox??? (evan2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evan2 &raquo;</TD></TR><TR><TD CLASS="quote">How about a TEST DRIVE..</TD></TR></TABLE>
a test drive? who'da thunk it?
kommon_sense is offline
Old 07-26-2004, 06:10 AM
Banned
Default Re: How to Check if the Civic is having LSD Gearbox??? (kommon_sense)
but both wheels must spin the same way when they are off the ground. an open diff will spin the other one backwards
Burke is offline
Old 07-26-2004, 06:21 AM
slimstajimsta5's Avatar
Default Re: (SlepT ej6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlepT ej6 &raquo;</TD></TR><TR><TD CLASS="quote">i dont know about you guys but i wouldnt let someone take out my axles jsut to check to see if i have lsd, id rather do a burnoutto show him or let him jack up the car and spin the wheels...</TD></TR></TABLE>
that test is bullshit. i have a stock civic dx.. and both of my tires spin when i did a burnout.. there's no way that they put LSD on a civic dx from the factory
slimstajimsta5 is offline
Old 07-26-2004, 07:56 AM
yes there are markings on the tranny, but i dont know if you would be able to see them.
gezer is offline
Old 07-26-2004, 12:32 PM
jdmsiR20's Avatar
Default Re: How to Check if the Civic is having LSD Gearbox??? (gezer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke &raquo;</TD></TR><TR><TD CLASS="quote">but both wheels must spin the same way when they are off the ground. an open diff will spin the other one backwards</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKallmotor &raquo;</TD></TR><TR><TD CLASS="quote">Jack it up, and spin one of the wheels. If the wheel on the other side spins also, the it has LSD.</TD></TR></TABLE>
nah... unreliable. with the lsd, it may possibly work that way...
but the only 100% way to guarentee it is....
jdmsiR20 is offline
Old 07-26-2004, 07:34 PM
stingie's Avatar
Default Re: How to Check if the Civic is having LSD Gearbox??? (Burke)
Thanks!! I think i will just do that...
stingie is offline
Old 07-26-2004, 08:07 PM
B A N N E D
Just check the top of the tranny it will say lsd stamped or in black stamped.
kaoss_11 is offline
Old 07-26-2004, 08:48 PM
RiceNmotioN's Avatar
just spin one wheel..if the other wheel spins the other way you have a syder gear..if it spins the same way it has LSD
RiceNmotioN is offline
Old 07-26-2004, 09:20 PM
Risky Business
BauleyCivic's Avatar
Default Re: (RiceNmotioN)
Okay, we get the point.
BauleyCivic is offline
daveypower
04-15-2012 11:20 AM
Spoon__EG6
12-22-2009 03:53 PM
lk5545
06-27-2009 10:34 AM
Driven
04-17-2006 09:02 PM
ukciviccoupe
06-24-2004 11:11 AM
Quick Reply: How to Check if the Civic is having LSD Gearbox???
  • Ask a Question
Question Title:
Description:
