d16y7 with z6 head into 92si
okay so my block is FUNKed up. so i bought a d16y7 from a guy on here
YES I SEARCHED
well someone said that the y8 timing belt has 1 more tooth so i need that.. but somebody else said the y7 and y8 belts are the same. some people said to use the y7 belt. which do i use?
i heard the timing will be off by a little bit.. but i can just use the Y7 camsprocketon the z6 head to correct this. i only heard this once and saw many posts on the z6 head onto y7 block. so will this work? camsprocket is the camgear, right? or what?
i'm going to be using my z6 wiring harness.... so all the shortblock sensors will plug right in, right?
i read the d15/z6/bauleycivic thread... and the d16y7/y8... and i guess on a d15 you need to take out the plug.. but not on the y7? the plug is on the y8 head for the y7/y8.. so im guessing i dont got to do anything about this, right?
is there anything else i should be on the lookout for? things i'll be reusing.... IM/HEAD/EXHAUSTMANIFOLD/ac/powersteering/tranny/starter.... anyone have any advice for me?
thanks. need asap will be building this tomarrow. o yeah im gonna use a y8 headgasket
YES I SEARCHED
Re: d16y7 with z6 head into 92si (lazynok)
my new d16y7 engine
the car its going in
if anybody remembers my old post when i used wooden jackstands (in signature).... i think you all will will be happy knowing i got some jackstands. my car fell on my hand (doing suspension, nothing to do with the wood) so i shaped up and got some stands =]
***correcton to the title of this thread... 94si
first off, nice to see you back
good thing u got jackstands too
what happened to the blue hatch?
and.... yes many of the things from the old hatch will be reused. axles, harness, shiftlinkages, starter, flywheel, clutch, tranny... all of it.
however, you do need somebody to come in and let you know what timing belt and sprocket to use.
good luck y0
good luck y0
blue hatch.. some nice guy met me on my blue hatch thread and offered to trade me. ******' good trade too.
i think he put a dart block into the blue hatchback i dont know.
well yeah i know about the reused... buy im not going to reuse the flywheel and clutch.. cause my clutch is almost dead. only thing im putting on is the block
1 Post
Re: (sheepeg3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheepeg3 »</TD></TR><TR><TD CLASS="quote">y8 and y7 diff belt...GL though i have y8 in my eg and its a wicked one...i beat up on egs with b16s and GSRs lol... have fun </TD></TR></TABLE>
your y8 beats b16's and b18c1's. sorry man, i just dont believe that one!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazynok »</TD></TR><TR><TD CLASS="quote">anyone? need to go buy timing belt in an hour or two...need quick answerr</TD></TR></TABLE>
well if you're using a z6 head and the blocks are the same height i would say use a z6 belt? measure the distance from the centre of each crank to the top deck of the block, if they are the same then get a z6 belt.. lol maybe just buy all three and return the 2 wrong ones!
1 Post
Re: (sheepeg3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheepeg3 »</TD></TR><TR><TD CLASS="quote">lol ...u in so cal??? and yes it does its crazy cuase i dunno how it does....i have no reason to lie...</TD></TR></TABLE>
i think there may be other factors in the equation, but lets not jack the thread!
Re: (coptzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thenick »</TD></TR><TR><TD CLASS="quote">what water pump/timing belt is needed for a y7 block with a z6 head?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">
For the water pump you always get the water pump for the block...so use the Y7. The Y7 and Z6 timing belts are the same length so either one of those will work.</TD></TR></TABLE>
i have the belt and waterpump for sale too
Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">
where do u live man. if u want to visit me im in tx with a y8 ihe in a 93cx. i havent lost to a b16 powered car yet and gsr hatches are good races.
jvillagran2000
27
12-03-2008 05:06 PM
keepinitsimple
02-17-2005 11:32 AM
