Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Model-Specific Technical Forums > Honda Civic / Del Sol (1992 - 2000)
Reload this Page >
steering wheel moving left and right when, minimal shaking at freeway speeds
Old 07-27-2004, 02:26 PM
Do_Ster's Avatar
Default steering wheel moving left and right when, minimal shaking at freeway speeds
hey guys, i got this problem. my car pulls to the right pretty hard, and i notice that when slowing down or accelerating slowly my steering wheel moves from left to right, left to right etc. at freeway speeds, there's some shaking but not bad. i already had an alignment done but it didn't fix the pulling to the right problem so i'm thinking that the steering wheel moving back and forth has something to do with the pull. i'm thinking either axles, steering components, or (long shot) bushings? thanks in advance for the replies.
Do_Ster is offline
Old 07-27-2004, 02:31 PM
electronb16si's Avatar
Vibration could be from warped brake rotors or maybe the tires are not balanced correctly. The pulling might be from a tire that is not going in the right direction (directional tire mounted wrong) When you got the alignment did you get the computer printout of the results? I can't think of anything that would make the car pull hard unless the alignment is still off.
electronb16si is offline
Old 07-27-2004, 02:44 PM
Do_Ster's Avatar
i don't think my rotrs are warped because the vibration occurs when i'm accelerating, also i have already had my tires balanced. like i said, i think that the steering wheel movement during slow acceleration and deceleration is related to the pull.
Do_Ster is offline
Old 07-27-2004, 02:47 PM
Do_Ster's Avatar
come to think of it, i remebered my rear left tire going bad so i replaced it and the pull was not as hard. then it got to the state that it is in right now. i had a rear disk brake conversion using teg trailing arms., could it be possible that the pull be due to a bent trailing arm?
Do_Ster is offline
Old 07-27-2004, 06:02 PM
Do_Ster's Avatar
bump
Do_Ster is offline
Old 07-27-2004, 10:11 PM
5w20's Avatar
Default Re: (ntogethernow)
you sir got a bad tire
5w20 is offline
Old 07-27-2004, 10:24 PM
Donkey85's Avatar
Default Re: (5w20)
check your outter tie rods for excessive play
Donkey85 is offline
Old 07-27-2004, 10:38 PM
ABK
ABK's Avatar
Default Re: (Donkey85)
when was the last time you got your tires balanced, check tie rods. Also if nothing check out, check if you universal joint or steering wheel itself got execive play in it.
ABK is offline
tvdc2
Suspension & Brakes
11-22-2016 01:08 PM
tkhang
01-04-2010 07:04 PM
buzlink
16
10-18-2007 07:41 PM
byronl
07-22-2006 05:30 PM
ixcryxblood
02-28-2005 02:30 AM
Quick Reply: steering wheel moving left and right when, minimal shaking at freeway speeds
  • Ask a Question
Question Title:
Description:
