YES!!!! How to wire a k20a into EG !!!!! pnp Harness!!!! THANK YOU HONDATA !!!!!!
http://www.hondata.com/techk20wiring.html
This is all you need. Thank Hondata for giving out that info and saving you $400. Thank me by supporting my cause k20a.org
Thank Hasport for giving us these nice mounts.
lol, thank me later
Thanks you Hondata and Hasport for all the support!!!!
lol, thank me later
Re: YES!!!! How to wire a k20a into EG !!!!! pnp Harness!!!! THANK YOU HONDATA !!!!!! (Rocks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocks »</TD></TR><TR><TD CLASS="quote">any info on EK wiring</TD></TR></TABLE>
Basically the same unless you have a 99-00 obd2.5
Details will be available as soon as people who know their **** read the diagram.
Guest
Posts: n/a
Re: YES!!!! How to wire a k20a into EG !!!!! pnp Harness!!!! THANK YOU HONDATA !!!!!! (Nikos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nikos »</TD></TR><TR><TD CLASS="quote">
I have a 99 si does it fall into my category
I have a 99 si does it fall into my category</TD></TR></TABLE>
Yes.
Yes.
Don't worry. Like I said , I am sure there will be more user friendly guides based on this.
For example, look at the ecu connector chart
and then look at ecu connector pinout. That is what those numbers mean.
I am sure me and others will try to break it down for those of you that are not very wiring friendly...
Basically, I wil tell u what plugs you need and how you need to wire them.
Re: (Nerologic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nerologic »</TD></TR><TR><TD CLASS="quote">wasnt this wirning into the EK covered in the SCC where they did the swap into that ek??? i recall going through like 4 pages of wiring info...</TD></TR></TABLE>
yes that was for a 96-98 EK....99-00 is slightly different b/c obd 2.5...plus the wiring on hondata's site is for a race car - which is slightly different/less complex thant that of a street (legal) car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocks »</TD></TR><TR><TD CLASS="quote">has anybody actually swaped a k20 in a 99-00 chassis . Im guessing its a bit more diffictult to wire up</TD></TR></TABLE>We (R CREW) can do OBD1, OBD2, and OBD2.5.
All PNP:
aLLmTRaLLdAY is running the OBD1 version
Ekizzle is running the OBD2 version
SuperTwinz (me) is running the OBD 2.5 version
So far we had made 2 of each and all of them work. I've been driving my car for over 3 months w/o any problems.
All PNP:
Re: YES!!!! How to wire a k20a into EG !!!!! pnp Harness!!!! THANK YOU HONDATA !!!!!! (SuperTwinz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperTwinz »</TD></TR><TR><TD CLASS="quote">We (R CREW) can do OBD1, OBD2, and OBD2.5.
All PNP:
So far we had made 2 of each and all of them work. I've been driving my car for over 3 months w/o any problems.</TD></TR></TABLE>
hook us up with all the schematics bro. especially the obd1. i am the one who has made all those pdf helms manuals you see all over the net. spread the knowledge bro.
All PNP:
Re: YES!!!! How to wire a k20a into EG !!!!! pnp Harness!!!! THANK YOU HONDATA !!!!!! (cxSHOE)
did anybody try to run a k20 on a obdI ecu, or is the obdI not smart enough to control a k20?
HT White Ops
Re: YES!!!! How to wire a k20a into EG !!!!! pnp Harness!!!! THANK YOU HONDATA !!!!!! (ABK)
I doubt a P28 has the computing power required to run VTC and a few of the other things that the K has.
Re: YES!!!! How to wire a k20a into EG !!!!! pnp Harness!!!! THANK YOU HONDATA !!!!!! (rochesterrice
yeah I though so, plus don't K series use coil packs as well?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rochesterricer »</TD></TR><TR><TD CLASS="quote">I doubt a P28 has the computing power required to run VTC and a few of the other things that the K has.</TD></TR></TABLE>
aahh..mmmm
aahh..mmmm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">did anybody try to run a k20 on a obdI ecu, or is the obdI not smart enough to control a k20?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brian g »</TD></TR><TR><TD CLASS="quote">No, it has to do with the number of times it pulses.
The No1 cylinder sensor pulses at TDC on the No1 cylinder.
The TDC sensor pulses at TDC for each cylinder.
The crank angle sensor pulses at various crank positions during the cycle.
Unfortunately it's a different number of pulses for the K-series engines compared to OBD 1/2 engines.
Using a computer that isn't set up for the correct number of pulses doesn't work.
http://www.k20a.org/phpBB2/vie...4402d
Re: YES!!!! How to wire a k20a into EG !!!!! pnp Harness!!!! THANK YOU HONDATA !!!!!! (JV)
Can someone help ?
I need to know in what cars I can find the grey plugs male and female that have that pinout?
I have seen these plugs in my 98 accord and 92 VX.
Is there any way I can buy a few new from somewhere?
Nikos
07-27-2004 03:32 PM
