need help with idle
Old 07-27-2004, 10:43 AM
bleedblue94's Avatar
Default need help with idle
i have a b16 swapped in my 98 hatch it was running off my p30 mugen spec ecu no prob i had the idle set at about 1000rpm and it idled great i swapped the ecu for a p28 skunk2 ecu and set the idel at 1000 again only now it starts that searching idle crap where it drops then goes up between 1050 - 700 i turned the idle screw down to 700rpm and it went away i know the p28 has the extra sensor for cold starts and that sometimes causes the same situation on obd2 b16 as im experiencing except that this happens at both cold start and fully warmed idle any help would be great
Old 07-27-2004, 10:52 AM
Donkey85's Avatar
Default Re: need help with idle (bleedblue94)
check your idle air control valve
Old 07-27-2004, 11:04 AM
Default Re: need help with idle (Donkey85)
its hooked up and i cleaned it not too long ago but ill check it again thanks
Old 07-27-2004, 12:10 PM
whoobeedoobee's Avatar
Try resetting the ecu.
Old 07-27-2004, 02:23 PM
Default Re: need help with idle (whoobeedoobee)
done that several times hasnt helped at all
Old 07-27-2004, 03:52 PM
TommyTom83's Avatar
i had the same prob with my ex, so i traded it in for an si... lol
thehig
05-20-2014 09:21 AM
Turbo_y8
05-05-2006 10:30 PM
89_crx
04-18-2005 06:26 PM
97hb
02-04-2003 10:24 AM
JdoggsGSR
10-26-2002 12:06 PM
Quick Reply: need help with idle
