steering problem
Old 07-27-2004, 01:33 AM
DudesHatch's Avatar
Default steering problem
how do u fix the steering wheel, when then steering ratio is high and all loose???
thanx
DudesHatch is offline
Old 07-27-2004, 02:02 AM
DudesHatch's Avatar
forgot to mention i have a 92 hatch cx ang recently got into an accident that his the right side off the wheel. and that's when all the loosness and alignment problem started. What should i start off doin.???? thanx
Old 07-27-2004, 04:56 AM
monicle's Avatar
Default Re: (DudesHatch)
well you should start off with an alignment. getting into a wreck isnt going to change your ratio so youre either not explaining the issue right or confused on terminology but in any event if you hit something before all this started, get an alignment and go from there.
monicle is offline
Old 07-27-2004, 05:44 AM
EHwithPotential's Avatar
A small hint/tip:
Jack up the side of the car that got hit and take the wheel off, once it is removed rock the rotor top to bottom, it it feels loose get a new wheelbearing.
EHwithPotential is offline
Old 07-27-2004, 06:38 AM
DudesHatch's Avatar
Default Re: (monicle)
not an argument, but can't the steering ratio change, like for example loose bolts, bushing, boot, tie rod or not to mention be recked and an alignment is done but steerin wheel still loose the steering is off. thanks people!
Old 07-27-2004, 06:44 AM
monicle's Avatar
the ratio is determined by the steering rack/gearbox itself. its the ammount of times you have to turn the steering wheel for how much degrees of the wheel turning. no matter if you have a bent controll arm, loose bolts, bent rim, whatever, unless the rack is physically damaged in some wacky way, the ratio will stay the same.
monicle is offline
qazaq
04-20-2008 03:26 PM
Panda0000
11-05-2007 09:36 PM
migizzel
12-05-2005 08:10 PM
Type R106
06-30-2001 07:39 AM
blind
04-28-2001 09:50 AM
Quick Reply: steering problem
  • Ask a Question
Question Title:
Description:
