Noise from engine somewhere?
Old 07-26-2004, 10:50 PM
matman4444's Avatar
Default Noise from engine somewhere?
My friend bought this 00 civic ex and when i was driving it around, in first gear there is a noise that sounds kinda like my teg's axles when i turn sharp but this is just driving forward and in first its the most noticable... when you speed up the noise speeds up, i can hear it a little bit in second and not really in third... any thoughts? maybe clutch or tranny i really dont know.. i hope he didnt get a lemon
yes i know my integras cv's are worn but its a similar sound
matman4444 is offline
Old 07-26-2004, 10:57 PM
ABK
ABK's Avatar
Default Re: Noise from engine somewhere? (matman4444)
maybe tranny, maybe the car was lowered or is too much and axles are worn to peices. if you are skilled enough you should just listen more closer and then take off the stuff you think is messed up and inspect it.
ABK is offline
Old 07-26-2004, 10:59 PM
hondachick05's Avatar
my car did that and it ended up being that the clutch wasnt connecting to the flywheel correctly anymore causing it to rub against it and making a wierd sound. are u having any trouble getting into gears or anything like that? I had to replace my clutch and that fixed my problem dotn know if thats the case with u though. i have a 92 civic
hondachick05 is offline
Old 07-26-2004, 11:04 PM
matman4444's Avatar
Default Re: Noise from engine somewhere? (hondachick05)
i know its not the axles because when we took the wheels off i could see they were fine... there wasnt really any trouble for me to get it in gear but i only drove it home from where we bought it... my friend, who has never driven a stick, has stalled a bunch of times from being in third... either being dumb and thinking it was first or not being able to get it into first im not sure
Old 07-26-2004, 11:09 PM
just drive it around for a few days cause it took my car almost a week to start messing up with getting into gear. teh noise came first and then a few days later is when i started having trouble. so to see if its the clutch i would drive it around for the next week regularly and see what happens. if it is the clutch then just buy a clutch kit and get it fixed keep me updated
PhrequenC
17
12-22-2007 09:05 AM
citrus3000psi
11-12-2007 02:23 PM
kajay1972
08-28-2007 08:12 PM
4everVtec
11
11-14-2006 04:44 PM
Pinhead
02-04-2002 12:37 PM
Quick Reply: Noise from engine somewhere?
  • Ask a Question
Question Title:
Description:
