I'm getting f'up Tire Wear!!!?
Old 07-26-2004, 10:45 AM
lowRIDAH's Avatar
Default I'm getting f'up Tire Wear!!!?
the tread on my rear tires is getting worn out just off the middle, more towards the outside. it's hapenning really fast. Why whould this be? are the tires over inflated??
ps this was going on even before i lowered the car.
thanks
lowRIDAH is offline
Old 07-26-2004, 10:48 AM
_BEN_'s Avatar
Default Re: I'm getting f'up Tire Wear!!!? (lowRIDAH)
having the middle of your tire wear is a symptom of over inflation so it could be that.
Your alignment could also be jacked to.
So check your tire pressure and if that fails go and get your car aligned. Some places offer a life time warranty (Ive heard) so maybe you can take the car back there and get it done for free when you upgrade your cars suspension.
_BEN_ is offline
Old 07-26-2004, 10:54 AM
JimmyAtlantis's Avatar
Default Re: I'm getting f'up Tire Wear!!!? (_BEN_)
Go by the tire pressure Honda says to use - it's probably printed somewhere in the glove box and says 32psi - DO NOT go by the max psi on the tire.
JimmyAtlantis is offline
Old 07-26-2004, 11:00 AM
94solchick's Avatar
Also, check your camber, it could be f-ed up.
94solchick is offline
Old 07-26-2004, 11:14 AM
Honda-Tech Platinum Member
Setsuna F Seiei's Avatar
Default Re: I'm getting f'up Tire Wear!!!? (honda92egchick)
If you're getting a wear pattern on ONE SIDE of the tire ONLY then that's camber wear. Middle of the tire wear pattern is overinflation, both outside sides of the tire is underinflation.
Setsuna F Seiei is online now
Old 07-26-2004, 12:03 PM
crashN2u's Avatar
Default Re: I'm getting f'up Tire Wear!!!? (BrokeAssPinoy)
It could mean you need an alignment and/or camber adjustment.
crashN2u is offline
Old 07-26-2004, 12:14 PM
SolObsession's Avatar
Default Re: I'm getting f'up Tire Wear!!!? (crashN2u)
Like everyone else said, check your psi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRI94 &raquo;</TD></TR><TR><TD CLASS="quote">Go by the tire pressure Honda says to use - it's probably printed somewhere in the glove box and says 32psi - DO NOT go by the max psi on the tire.</TD></TR></TABLE>
Why do you say not to go by the tire's printed psi? I have always been under the impression that that is the best psi for that tire for daily driving.
SolObsession is offline
Old 07-26-2004, 12:59 PM
Sijray21's Avatar
Default Re: I'm getting f'up Tire Wear!!!? (SolObsession)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SolObsession &raquo;</TD></TR><TR><TD CLASS="quote">Like everyone else said, check your psi.
Why do you say not to go by the tire's printed psi? I have always been under the impression that that is the best psi for that tire for daily driving.</TD></TR></TABLE>
lol, that's the maximum tire pressure for that tire under the load spec. Any more and it's unsafe. Go with 32 psi (in most Honda Manuals) all around can't go wrong with it (tire pressure is different for everycar under factory specs, but 32 is a good average). This is for daily driving right?
this problem is sounding like heavy over inflation. camber-wear will just wear the insides and toe wear will wear in patches. When was the last time you had an alignment?
Sijray21 is offline
Old 07-26-2004, 01:19 PM
timka's Avatar
yah man Im having same problems with my front tiers. I changed them last week. and that was the third time that I had to change them in 7 Months.
timka is offline
Old 07-26-2004, 02:23 PM
egyolk's Avatar
over inflation
your tires need some tums
egyolk is offline
Old 07-26-2004, 02:35 PM
lowRIDAH's Avatar
Default Re: I'm getting f'up Tire Wear!!!? (oversteerINGS)
that's what i was suspecting, both tires are scrap so i'm getting new tires and geting alignment done.
thanks a lot
lowRIDAH is offline
Old 07-26-2004, 02:55 PM
fishnfst's Avatar
I get inside tire wear from toe adjustments and camber. My outside wear comes from hard cornering. Center wear means overinflation....
fishnfst is offline
Old 07-26-2004, 03:16 PM
beaterdriver's Avatar
what if the hub was bad, and caused the wheel to "shimmey", that is what is wrong with my car, the front driver side hub is bad and caused the wheel to vibrate and its wearing out the entire contact patch
beaterdriver is offline
da9leo
10-17-2008 12:44 PM
BanEL
06-04-2006 12:28 PM
torqueless
01-12-2005 08:47 PM
mnbv
07-21-2004 07:00 AM
Jammersplace
12
03-08-2004 12:32 PM
Quick Reply: I'm getting f'up Tire Wear!!!?
  • Ask a Question
Question Title:
Description:
