JDM b16 having the same problems as my old B16a3
SOMEONE HELP ME! PLEASE!
i had a b16a3... and about 110,000 miles it started losing power then finally my distributor went out... so got a new distributor... out back in time.. and then it stuttered til vtec and when it went into vtec it would haul ***... and i just had gsr cams installed too! now i have a jdm b16a sir-II and its missing a knock sensor that i need but it still stutters til vtec but not as bad and i can only run vtec til 7500 rpms and it cuts out! anybody know what the hell the problem is?!!!!!!
Modified by birds_sol_94 at 4:07 PM 7/26/2004
Re: JDM b16 having the same problems as my old B16a3 (birds_sol_94)
Stuttering can be caused by things like fuel pump/spark plugs/o2 sensors gone bad/and even timing issues. Could you have messed something up on when you installed those gsr cams? Did you install them on the new motor? What ecu are you using on your new motor? Did you have an obdI Del sol w/stock b16? If not what ecu were you using hten? Some things to consider...
Re: SOMEONE HELP ME! PLEASE! (birds_sol_94)
Alright.. i now have a JDM b16.. running a p30 on a p30 motor... no gsr cams installed on the new motor... but im missing a knock sensor b.c hmotors is being an ***! has a new fuel filter... new distributor... cap.. rotor button.. plugs.. wires.. but i still cant figure it out!!!!????? and its running obd1
sLyBlAzNbBoI
03-06-2011 05:18 PM
