HP quotes?
Re: (mynismo)
No.....127hp is at the flywheel...you guys got to learn...that 15-20 hp is loss from the transfer of power from the flywheel to the transmission then to the wheels and then the ground....
so only 100hp or even less...that's why when you go to the dyno you get less hp reading.....127hp is at the flywheel....
Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL »</TD></TR><TR><TD CLASS="quote">I'm sure he was asking what the engine is rated as.
127hp is what the engine is rated...
Actually has about 109 calculated using a 15% loss through the drivetrain.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MNEJ1GUY »</TD></TR><TR><TD CLASS="quote">No.....127hp is at the flywheel...you guys got to learn...that 15-20 hp is loss from the transfer of power from the flywheel to the transmission then to the wheels and then the ground....
so only 100hp or even less...that's why when you go to the dyno you get less hp reading.....127hp is at the flywheel....</TD></TR></TABLE>
Some people trying to be smartasses I tell ya......
Re: (specv5150)
I rather be a smartass than a dumbass.... true....true......
And calculating use percentage is BAD you will lose the same amount of HP even if your engine is make just 100hp or doesn't matter if your make 500HP...same amount of Hp is loss through the drivetrain....
In this world there are only 2 options....
option one: Dumbass
option two: Smartass
no more no less.......
It's either you know or you don't.....true...so true...
Modified by MNEJ1GUY at 12:09 AM 8/14/2004
option one: Dumbass
Re: (MNEJ1GUY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MNEJ1GUY »</TD></TR><TR><TD CLASS="quote">I rather be a smartass than a dumbass.... true....true......
option one: Dumbass
Modified by MNEJ1GUY at 12:09 AM 8/14/2004</TD></TR></TABLE>
okay...............
option one: Dumbass
okay...............
