[FAQ] Hood Weights
Tons of crappy information out there for a good topic... If you've got GOOD information (not just from your arm scale) please PM me and I'll add it up. If you find any of the numbers to be wrong, please also let me know that.
EG
Stock - 31lbs
Fiber Images CF OEM - 15lbs
JDMShit CF OEM - 18lbs
MB Fiberglass OEM - 15lbs
VIS CF Evo - 16.5lbs
VIS CF OEM - 18lbs
EK
Stock - 32lbs
VIS CF OEM - 16lbs
EG
Stock - 31lbs
VIS CF OEM - 18lbs
EK
Stock - 32lbs
VIS CF OEM - 16lbs
Good post thanx man.
not to disprove what you are saying but my vis hood weighs only 16.5 pounds, i weighed it before i put it on, i have the evo hood and there is a big hole in it that might be the difference because i expect you are talking abou oem style hoods?
good info
Good post.
This will cut down on a lot of CF hood threads.
I got a VIS carbon hood for my 97 Civic hatch
EK
Factory 32lbs.
VIS (OEM) 16lbs.
EK
Factory 32lbs.
VIS (OEM) 16lbs.
bump for fiberglass!!!
bump cause im going to weigh my bodykits NW full cf hood when i get home
good info fellas
got a fiberglass number
Whats the difference between a fiberglass hood and fiberglass hood skin? I'm guessing it doesn't have the underskeleton? Is the 7lbs one listed for the skin or the whole hood?
http://www.imagineengineering.com/fiberglass.htm
Edit: Answered my own question. Skin is without the skeleton. Still wondering if the 7 lbs is skin only.
Modified by jolt-tsp at 9:07 PM 8/25/2004
good info
good idea for a thread man. ill be referring back to this alot
bump for good info
Where can I get a OEM fiberglass hood for my EG hatch ?
good post, what about trunks tho??
I forgot more about hondas then you will ever know....
EG
Stock - 36lbs
EG
Stock - 36lbs
I was told the MB fiberglass hood doesn't allign correctly with 92-95 civics made in canada? Does anyone know if its true?
Great information! Anyone got one on trunks/hatches?
Originally Posted by vtec69
good info
B18C-Hatch-Turbo
12-21-2004 12:00 PM
Previous Thread
Next Thread
