car cranks but wont start, died on the road
just did a d15 vtec swap and it went off without a hitch, got it done in about 3 hours, used a civic si tranny (hydro) and a manual p28 computer, with a usdm vx engine harness, and a jdm vtec distributor. anyway it was running fine until all of the sudden it shut off while i was driving, about three weeks after i did the swap. the engine cranks excitedly and everything works electrically in the car, ive got a hot spark and thetiming belt is fine, also the fuel pump is putting out 38 psi and all the injectors ohm out. WTF is going on? ignition? help im frustrated
Re: car cranks but wont start, died on the road (jdmd15b)
have you checked the distributor rotor? My car suddenly died while driving and it turns out the set screw on the rotor backed out and screwed the timing up. When I pulled of the distrubutor cap the rotor fell out into my hand
Re: car cranks but wont start, died on the road (SlowMotion)
i agree with the rotor, and my hatch sometimes does the same thing, it will just die out of nowere, i usually just remove the negative cable and re-set the ecu and it works fine after that
Re: car cranks but wont start, died on the road (HondaMoCo)
Check that all your grounds are on tight, Did a clutch on a friends prelude and one ground for the harness was loose and the car did the same as yours is.....tightend the ground and she started right up
i would check your timing belt just in case it broke , u never know it happened to me before on my escort but my engine didnt blow up
thanks for all the ideas guys, the problem was actually the wires and the cap/rotor, the only firing plug wire happened to be the one i used to test spark, the other three were'nt sparking the rotor had broke and the cap was shot, thats what i get for buying a used jdm distibutor from ebay and not changing that stuff right away, i went with the msd cap and an external blaster coil
i was just going to suggest Fuel or Ignition.... if the car will start with starting fluid... its fuel... if it doesn't its ignition
Re: car cranks but wont start, died on the road (hondainspired)
was it just a slow loss of power? mine just slowly lost power, i had it in first and punched and i was slowing down. if so, it's your dist. the exact same thing happened to me. it was getting fuel, just no spark. i could sit and crank all day, but it wouldn't start.
MinimusMaximus
11-12-2011 07:47 AM
99cx
13
02-25-2010 03:02 PM
the_hatch_17
07-06-2005 02:36 PM
phoboyjimmy
10-14-2002 08:38 AM
