I keep popping my speedo fuse?????
I just got my engine back in and now the speedo fuse pops if I get above 60 or so. I've bumped it up to 10 from 7.5 and it still happens.
Anyone ever seen this before?
Re: I keep popping my speedo fuse????? (Art In Motion)
Actually, I put in a 30A (getting desperate) and now I can do about 80 before the fuse blows. Still not high enough to get me to the drag strip.......I'm thinking about hard wiring it.
Re: I keep popping my speedo fuse????? (smokinsi)
you know, i think the reason why theres a fuse in there is to prevent an excess of current from travelling thru your electrical system. so if you keep allowing that much current, like 30 amps is a lot, then you're going to start frying other things as well. i think you're going in the completely wrong direction. find the problem at the source and dont hard wire it, that could only make things worse.
Re: I keep popping my speedo fuse????? (EKcivicEX)
Take your gauge cluster out and see if the wires behind it have evern been messed with. Sounds like to me you have a hot wire touching against something. Also check the wiring down at the fuse box and at the ECU for wiring that is just twisted together.
Re: I keep popping my speedo fuse????? (Evil_Wizard)
The crazy thing is all I've done is rebuild the engine and didn't touch anything else. The car is practically brand new, 26k. Nothing inside was ever touched. this sucks.... I autocrossed today and the car worked fine until I broke the 80 mph mark then the fuse would pop and no vtec. luckily it was at the end of the course.
Just to help out incase anyone's doing a search on this.
The problem was the secondary 02 was grounding out on the body. This somehow caused the fuse to blow at higher speeds crazy.....
GreenD16Y8
08-08-2005 03:59 PM
1995, 93, 94, bigger, delsol, fuse, gauges, honda, location, poping, popping, put, speedofuse, speedometer, speedomoter
