Lining up motor mounts for droppin' engine in
Re: Lining up motor mounts for droppin' engine in (spyderracing32)
uhh...use your cherry picker and just line it up, and then lower it. BOOm there you go. and when you first put the bolts in dont tighten them all the way yet. just incase you neeed it to play alil bit so all of them line up not much trick involved just strait forward and easy
ya you arent just droppin the thing in. its not that hard. you slowly lower it in. and stop any time you need to make adjustments.
Re: Lining up motor mounts for droppin' engine in (usdmike)
got it! take off the rear mount and do that seperately, tranny side first y0 hahaha im psyched!
i angle the tranny side lower than the rest of the motor for clearance...... bolt in the two upper mounts, and then use a floor jack to line up the rear mount.......
civicboy420
07-27-2014 07:29 PM
