Exhaust questions. NOT a pic request
* B A N N E D *
sup guys, i'm doing a lot of research on exhausts and im not sure about piping size. i was really looking into getting an RS*R ExMag, but the 60mm piping turned me off. i then thought about the HKS HiPower, but looking into it, that has 55mm piping. i cant find any documentation on the piping size of the APEXi N-1. so i guess my real question is, if i plan on boosting my D16Y8, what size piping should i look into getting? is 60MM really that small? i havent found an aftermarket catback that was bigger than 60.5MM
1 Post
Re: Exhaust questions. NOT a pic request (Veritek)
60 mm is 2.3 inches. You might want to go a little larger if you're planning on running a bunch of boost. Bigger exhaust=less back pressure on the turbine side
* B A N N E D *
Re: Exhaust questions. NOT a pic request (hatchling37)
if i decide to swap instead of going boost, would a 55mm exhaust be ok? i know an all motor application, a little back pressure is good. if anyone has any dyno's with various piping sizes, boost, or N/A i'd appriciate it.
