Misfiring at low rpms????
okay, i redid my valve lash/adjustments again and replaced the rotor and cap and spark plugs but the car feels like it is misfiring at idle, could it be doing this because of all the times i took the spark plug wires out and they got damaged or does anyone have any idea why this would happen, if you would like to get better idea i will post a video up of it tomorrow, thanks in advance.
Re: Misfiring at low rpms???? (electric-boost)
i'm not getting any codes... i will get a video up so you can see what i am taking about it idles fine but in regular intervals there is a lower tone thump not loud or anything, i cna feel it in the shifter and the engie rocks a little
Re: Misfiring at low rpms???? (Soccerking3000)
my buddy has this too.....don't know why...no codes too..a small thumb..and rpm drop like 200 rpm, less than 2/8 of a second....happens every few minutes at idling..
Re: (Dimi)
see i cant really do my timing cause when i have the timing gun working, you need ot have the engine at a steady 750 rpm or so, my car idles up and down, its not a vaccuum leak though, it seems to idle fine then all of a sudden it dropps 100-200 rpm, and it makes it pretty much impossible to get it right
well my timing is way out in left field and hasnt made a noise like that so idk
was it like a deep hmmmmm noise and then the engine idle went down? cause if so mine did that in a parking lot last night but only has done it once since the timing was fucked a month ago
Modified by electric-boost at 11:03 PM 8/12/2004
Re: (electric-boost)
and after it drops it goes right back up pretty quickly if it was a vaccuum leak it would be a steady up and down buts is very quick up and down then its fine then up and down every 5 seconds or so it does it
yo i got the same problem!!! i've tried everything to fix it. i did a oil change and spark plug change and it started happening. i replaced wires, spark plugs, car, rotor, checked vacum, intake, everything and i havent solved it yet. and it seems to be worsening.
Electrician
If I go by my tachometer, I'm idling at 100 RPM which is not possible. My RPMs also go up and down every minute or so. I'm thinking it has to do more on the power surge side. When the fan or something is triggered, voltage gets drawn so I'm guessing the main harness' voltage goes down which might cause the little drop in RPM.
Re: (jbscivichb92)
well a ne engine isnt quite in my budget, see when i drive it it will sharply decline about 50-100rpm then go back up, when i drive and go to stop it will idle fine for about 10 seconds then start doing it again. could this because of a ground being dislodged?
srt4pilot
33
06-22-2009 09:36 PM
Chronicsinners
02-04-2005 02:41 PM
