*CTR SRS steering wheel help*
Old 08-12-2004, 11:17 PM
DeviousCTR's Avatar
Default *CTR SRS steering wheel help*
ok for those who have the SRS CTR steering wheel in their EK i need your help. I swapped my SRS CTR wheel in last night and i have one problem to ask u guys.. does your SRS light stay on when youre driving? Mines comes on and i need help on how to turn it off? what makes it stay on when i start the car and drive it?
Any help would be great thanx..
Old 08-12-2004, 11:45 PM
OpTiX619's Avatar
Default Re: *CTR SRS steering wheel help* (DeviousCTR)
not sure with compatibility between jdm and usdm airbags. if you had the battery hooked up when switching bags, your srs probably noticed a disruption and shut itself down to prevent accidental deployment. try resetting the system, i searched hondatech. you should only need a paperclip to reset it...
Old 08-12-2004, 11:48 PM
OpTiX619's Avatar
Default Re: *CTR SRS steering wheel help* (OpTiX619)
https://honda-tech.com/zerothread?id=920677
for an odyssey but should do the trick...
https://honda-tech.com/zerothread?id=264288
more elaborate link for your civic
Old 08-12-2004, 11:59 PM
DeviousCTR's Avatar
thanx optix.. i disconnected my battery cable before i disconect the srs plugs and remove the steering wheel.. so basically u have to reset the srs light? ill do this once i find out wat a SCS service conector is and what eh MES plug looks like thanx
Old 08-13-2004, 12:04 AM
OpTiX619's Avatar
Default Re: (DeviousCTR)
the mes connector should be under your dash so you do not have to disconnect the airbags again if that is what your thinking. if you do a search for "srs resetting" under archived files, there may be a post with images still available.
btw all of the srs stuff is yellow. the MES connector is two wires with a yellow connector. it may be hooked to something that will just hold it in place.
Old 08-13-2004, 12:05 AM
DeviousCTR's Avatar
thanx im searching the archive rite now.. i appreciate your help
Samer
10-13-2011 10:14 AM
f_l_g
09-29-2006 06:20 AM
Airbag Club
13
01-11-2003 06:22 PM
Quick Reply: *CTR SRS steering wheel help*
