150 MPG?!?! Horrible gas mileage?! im lost
i just swapped a y8 into my 98 dx hatch.. it was formally using a Type R motor, and all the fuel accessories with that (i.e. fuel pump)
i have a map sensor code, secondary O2 sensor code, and intake air temperature..
and i only got 150 mpg???
help me with suggestions please
Re: 150 MPG?!?! Horrible gas mileage?! im lost (2lua)
im confused.. how do you get a 150 mpg? to me that would be great you'd save alot on gas but i dont think its possible LoL and i cant figure out why you'd say its horrible :-D
lol i mean 150 miles to my full gas tank lol
sorry about that mix up...
but normally i got 35-40 mpg and right now im getting like 17 mpg....
i dont think the secondary should throw it off that bad@!?@?@?@?@ ii hate it
Re: 150 MPG?!?! Horrible gas mileage?! im lost (mugenhatch92)
When my 98 hatch's (stock y7) Primary O2 died I went from 30mpg to low 20s, I replaced the sensor and all is back to normal. You must be running rich as Trump, fix the codes and then see whats up.
Re: 150 MPG?!?! Horrible gas mileage?! im lost (AphexMatt)
A base fuel injector pulse width is referenced by two inputs - RPM and MAP.
You have a code for the MAP - well I don't think the ECU is gonna want to rely on what your MAP sensor is spitting out since its already deemed a problem with it....so since it has to use something for an input, it uses a back-up set of values to allow you to limp home and FIX the problem.
Re: 150 MPG?!?! Horrible gas mileage?! im lost (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">A base fuel injector pulse width is referenced by two inputs - RPM and MAP.
You have a code for the MAP - well I don't think the ECU is gonna want to rely on what your MAP sensor is spitting out since its already deemed a problem with it....so since it has to use something for an input, it uses a back-up set of values to allow you to limp home and FIX the problem.</TD></TR></TABLE>
i only got a little bit of that lol
yes i need to fix the secondary 02 for sure
A bad MAP sensor & O2 sensor will give you awful mpg, fix them, and you will see much more normal mpg..
When your car is running too rich or too lean it ruins the o2 sensor. My o2 stopped cycling when my car was running lean it also stopped working when my car was running too rich...
bmw626
31
06-05-2005 04:58 AM
ViVaLaLude00
11
02-15-2004 05:24 PM
