Civic backfiring & stalling. speedometer going crazy.
??? Civic backfiring & stalling. speedometer going crazy.
93 Civic DX with 213,000 mi.
So last week my car began acting really strange. After driving for about 10 minutes or so, the speedometer began flopping around, then suddenly the car began to backfire and bog down. It eventually stalled when i came to a stop.
after 15-20 minutes i could start it again, and go a few more miles, then it happended again. I replaced the distributor, rotor, cap, plugs, oxygen sensor, before giving up and taking to a shop. They told me it was a bad ECU, but they wanted to get it from the dealer for $750, so i took it home and bought one myself.
this did no good. The problem still exists. Also directly after the car stalls and i try to start it, the engine light is not on, and i do not hear the pgm-fi relay clicking, but when i turn it over, the warning light will come on but it is very dim. I am wondering if it might be the relay itself.
Any help would be greatly appreciated. I'm getting tired of replacing parts for no reason....
Modified by exbanious at 7:51 PM 8/12/2004
Re: ??? Civic backfiring & stalling. speedometer going crazy. (exbanious)
i'm not sure of the problem, but it may be the ground on the motor. try cleaning/replacing the ground wires.
hmmm ECU for $750 that's crazy. that's like a new d-series motor!!! 213k miles sounds like it is starting to break down, maybe time for a swap? stop wasting money on parts that might still be good on your motor, those $$$ will add up for a new swap.
Re: (H.A.R.T b16a1crx)
well, i replaced the ignitor when i replaced the distributor, that was one of my first thoughts when it started heppening. i thought at first it was something mechanical, but because the speedometer is going crazy at the same time, I am thinking more and more that it might be a ground somewhere. could the alternator be surging or something? there is corrosion aorund the battery, but i get a good reading of 12.5v off it consistantly when not running.
Re: (JasonBrown)
my only suggestion is that your car has probably become possessed. This usually only happens to cars when they are between 180,000 miles and 220,000 miles. You need to have a religious ceremony and somehow solve this problem. maybe a sacrifice of some sort might fix it. like..... step on an ant or something. dont try to get a swap because your car will still be possessed and the engine will never fire. just a tip.
Try taking the exhaust manafold cover off and check for cracks in the manafold. I had the same problem and ended up having to replace my manafold because of a large crack.
Re: ??? Civic backfiring & stalling. speedometer going crazy. (bcampbell)
have a local shop test the battery and alternator when the car is running and you will know if the battery or alternator is going bad.
Re: (SleepyCx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepyCx »</TD></TR><TR><TD CLASS="quote">could be a bad ground... or a main relay</TD></TR></TABLE>sounds like something along those lines...
Re: (92RED Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92RED Hatch »</TD></TR><TR><TD CLASS="quote">sounds like something along those lines... </TD></TR></TABLE> thank you i try... but if his car is wigging out (speedo) then its prolly a ground or a short.. there inst a mechanical problem with that... mine had a hardcore stumble that went away but i was stumped for a while... and if it makes a clicking sound.. mine did that too and that was an alternator problem.. but a bad ground will do that too.
Re: ??? Civic backfiring & stalling. speedometer going crazy. (handa)
yeah I have to agree with that one, a lose or bad ground will make all those things happen, check the one on the tranz and it don't hurt to add more, to the eng to the chaise good luck
Re: ??? Civic backfiring & stalling. speedometer going crazy. (d16y8 4u)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16y8 4u »</TD></TR><TR><TD CLASS="quote">alternator? happened to me before</TD></TR></TABLE>
Two days a my coworker's car started acting the exact same way (Jeep Cherokee, but still same symptoms). IT was an alternator. New alternator and not exorcism was necessary. Bad grounds sound plausible too.
Good luck!
Good luck!
Re: ??? Civic backfiring & stalling. speedometer going crazy. (ubercerealkiller)
well, don't i feel stupid.
i cleaned all the ground wires that i could find, tested the connections
and took the car out for about 25 minutes......i encountered no problems.
i suppose the true test will be the ride to work tomorrow.
If its going to fail, it will do it when i need it not to most.
thanks for all of the advice.
ya, i would think either the ground wires or the main relay, this bullshit abour praying and crap...go kill yourself
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murmur9 »</TD></TR><TR><TD CLASS="quote">ya, i would think either the ground wires or the main relay, this bullshit abour praying and crap...go kill yourself</TD></TR></TABLE>
the more and more posts i see made by u. i realize, YOUR A ******* IDIOT and if u wanna take **** that doesnt even pertain to you and make it personal i think u should just leave H-T altogether.
civicali
01-14-2019 05:48 AM
saidinjest
01-23-2012 10:14 PM
