Blinker stopped blinking
Ok jsut like 5 minutes ago i was tring to fix my blinker problem.. (bulb keeps popping out of socket) well i fixed that then put my blinkers on and they worked.. but then the bulb popped back out again... so i unplugged my battery and then tried to fix it again.. well then neither of the blinkers worked... but the hazzards both lit up.. i checked all the fuses.. all fine... what else could it be...
Re: (qi_doy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qi_doy »</TD></TR><TR><TD CLASS="quote">Blinker fluid</TD></TR></TABLE>
dang you beat me....
Electrician
Re: (qi_doy)
You really don't know what you have started.
ok i could be an idiot and go along with the blinker fluid thing.. but i know a little more then that.... but all the fuses are good.. and every thing works except the damn blinkers...
Electrician
The relay is usually a black little box that is under your dash. Usually about 1.5" x 1.5" that unplugs and has 2 or sometimes 3 prongs sticking out of it.
Re: (Proglow3)
The hazard/turn signal flasher is a small square relay located on the interior fuse block under the left side of the insturment panel.
When it's working properly it will make a distinct clicking sound. If the turn signal fail on one side or the other and the flasher unit doesn't make its characteristic clicking sound, look for a faulty turn signal bulb.
If both turn signals fail to blink, the problem may be due to a blown fuse(in the engine compartment fuse box), a faulty flasher unit, a broken switch or a loose or open connection. if a quick check of the fuse box indicates that the turn signal fuse has blown, check the wiring for a short before installing a new fuse.
-Haynes "Civic & del SOL", chap. 12-3
N~FaMouSKhMerBoi
03-18-2004 11:55 PM
