B18b auto
B18b auto
Hello i came across a swap a few months back and i went for it (don't flame to hard on me ) got a 94 integra complete swap (AUTO) so that my girl could still drive it while i was working on my next project so here is the deal i done the swap everything went well at frist i got the car up and running now i am having trouble switching gears all i have is 2nd and overdrive and i have no clue what to do on it been trying to figure it out on my own for sometime so now it is time to turn it over to the pros the car i have is a 92 hatch .. i am thinking it has something to do with the ECU but i am not sure any thing you guys can suggest to try besides selling the car /swaping to a 5 speed/ i know i am asking alot but if you could help in any way i would be very greatful
Thanks
llll_fusion_llll
92 Hatchback
b18b1
Thanks
llll_fusion_llll
92 Hatchback
b18b1
Re: B18b auto (llll_fusion_llll)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by llll_fusion_llll »</TD></TR><TR><TD CLASS="quote">Hello i came across a swap a few months back and i went for it (don't flame to hard on me ) got a 94 integra complete swap (AUTO) so that my girl could still drive it while i was working on my next project so here is the deal i done the swap everything went well at frist i got the car up and running now i am having trouble switching gears all i have is 2nd and overdrive and i have no clue what to do on it been trying to figure it out on my own for sometime so now it is time to turn it over to the pros the car i have is a 92 hatch .. i am thinking it has something to do with the ECU but i am not sure any thing you guys can suggest to try besides selling the car /swaping to a 5 speed/ i know i am asking alot but if you could help in any way i would be very greatful</TD></TR></TABLE>
That's quite the run-on sentence.
Re: B18b auto (hatchling37)
I went back through the car and made sure that it wasn't the linkage that was my frist thought ...... one thing is that i can put the car 1st and switch to 2nd and it is the same gear and D3 and D4 are the same ... the car will not pull it's self in D3/D4 at all (most of the time) i had it do right one time and put it in park to see if it would do it again and i got the same crap as before lol maybe i just need to install a new tranny..but i drove the Integra before i pulled it out and it was fine in it .
llll_fusion_llll
llll_fusion_llll
Re: B18b auto (green00EX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green00EX »</TD></TR><TR><TD CLASS="quote">
That's quite the run-on sentence.</TD></TR></TABLE>
Tried to tell ya....
When you do the linkage, pull the shifter lever all the way down to the bottom to D2 or whatever is on your car. Then when you pull the lever on the transmission (after you take the plate cover off) and pull that back all the way so you know it's in the same position as the last spot on your shifter inside. Then reconnect the cable and test it out.
Also, did you pull the TCM out as well and put that into your car? Besides using an auto LS ECU, you need the tranny computer also.
Did the ECU come with it....and IS the ecu a auto ecu or manual. I threw on a manual ecu to an auto swap....(got the wrong one off of ebay) and i only had 2nd gear and 3rd i think. it wouldnt start in first gear eather. it would take FOREVER just to get up to like 20mph. it pulled rally hard...{like trying to take off in 3rd on a manual from a stop. }
do you have reverse? if its not the ecu, try looking on the tranny, did you plug the right cables into the tranny, or are any of the wires loose. (i also had a problem with the wire on the tranny, and i never got 4th or overdrive..whatever)
Re: B18b auto (Newman)
You know now that i think about it i didn't get the TCM i bet that is the problem Thanks for all your help and reply's on my stupidity lol well if any one has a TCM for a LS auto i would like to buy it
llll_fusion_llll
llll_fusion_llll
yask4it
13
10-09-2011 05:26 PM
Rsporty
02-13-2010 05:29 AM
