stainless steel clutch lines
i have a ej1 and the clutch feels horrible i think the master cylinder is going out so im replacing that. but my ? is will stainless steel let me build more pressure in the clutch? i have heard the rubber hoses flex alot so you can only build so much pressure. so will the stainless steel lines let me build more? thanks for the help
Re: stainless steel clutch lines (sohctodohc)
I don't know if stainless steel lines would help at all, but stock clutch lines aren't rubber hoses. It's a metal line (not sure what kind of metal though). You can follow it from the clutch master cylinder all the way to the slave cylinder.
Re: stainless steel clutch lines (******)
i have one but i cant ya if it made a diffrence or not. i replaced it during the swap.
got mines from heeltoe and the quality is amazing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** »</TD></TR><TR><TD CLASS="quote">I don't know if stainless steel lines would help at all, but stock clutch lines aren't rubber hoses. It's a metal line (not sure what kind of metal though). You can follow it from the clutch master cylinder all the way to the slave cylinder.</TD></TR></TABLE>
the hard line ends once the line goes from the frame to the slave cylinder. They put in a rubber line because of the engine movement. Looks just like a rubber brake line.
To the poster, I don't know if the SS lines do anything either. But at $35 or so that they sell for, I'm gonna do it on mine. Can't hurt I figure.
s
s
Re: stainless steel clutch lines (stevel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevel »</TD></TR><TR><TD CLASS="quote">
Yep that's right.
If you end up using the stainless steel line, post a review for us.
Yep that's right.
Re: stainless steel clutch lines (Slopoke)
yea i was goning to say i think there is maybe 3 rubber hoses throughout the lines. but i figured with the flex in those hoses would leak the pressure out so im gonna try this. i think we all know the stock clutch in a ej1 feels like ****. or atleast mine has from day one.
B_Swapped93
12-14-2012 04:32 PM
