14" steelies over GSR brakes?
Did a search, but just want to clarify since there are differing opinions. Can you fit 14" steelies over GSR brakes without having to grind the calipers or use spacers?
Re: 14" steelies over GSR brakes? (EJellyfish1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJellyfish1 »</TD></TR><TR><TD CLASS="quote">yes they will fit.</TD></TR></TABLE>
I can confirm.
I can confirm.
1 Post
Re: 14" steelies over GSR brakes? (ek9hatch0WN3R)
You may want to test fit before buying - I had one POS aftermarket steelie that would not fit after I swapped over to 96 Teg brakes on my 93 hatch - the OEM Steelies fit, but in my case, the aftermarket 14" did not.
I've got 14'' steelies on my eg w/ integra brake knuckles and calipers w/ 10.3'' rotors.
Yeah, they should fit, but I once had a flat and tried putting the doughnut on the front...not even.
Re: (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox »</TD></TR><TR><TD CLASS="quote">Aren't the OEM steelies 13'? Will the Teg brakes fit over these?</TD></TR></TABLE>
i think for civic hatches they're 13" ..integras are 14" though. And no, 13" steelies won't fit over teg brakes.
H-T Order of Merit
Re: (Dengar)
I thought VX rims were alloy's, not steelies.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adnoh »</TD></TR><TR><TD CLASS="quote">but I once had a flat and tried putting the doughnut on the front...not even. </TD></TR></TABLE>
Has anyone with integra brakes on their hatch tried putting an integra spare tire in the spare tire well? Does it fit?
Re: (TouringAccord)
i didn't mention what material each were because the vx\hx have a rim made of alloy like mentioned. where as the cx had a steelie.
Regardless they are all 13 inch wheels.
Correction the alloy hx wheels are 14's the cx stelies are 13's. Yes 14" steelies will fit over all but the itr brakes. I have 14" steelies over 99si brakes in my 98 hatch....
H-T Order of Merit
Re:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord »</TD></TR><TR><TD CLASS="quote">Has anyone with integra brakes on their hatch tried putting an integra spare tire in the spare tire well? Does it fit?</TD></TR></TABLE>
Specifically the 92-95 Civic Hatchbacks?
Re: 14" steelies over GSR brakes? (Dengar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dengar »</TD></TR><TR><TD CLASS="quote">
I can confirm.</TD></TR></TABLE>
same here
same here
Re: 14" steelies over GSR brakes? (93CivicSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CivicSI »</TD></TR><TR><TD CLASS="quote">steelies on the EX and the Si were 14" from the factory....13" on all others...</TD></TR></TABLE>
were the 14" EX steelies black or silver?
SiR/Si uses 14" OEM steelies as snow tires (some do), and since SiR/Si have the same brakes as Integra, therefore, 14" OEM steelies will fit over the brake calipers.
Re: 14" steelies over GSR brakes? (Hatchy-Ownzjo0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchy-Ownzjo0 »</TD></TR><TR><TD CLASS="quote">They fit over my GSR brakes.. I only have GSR brakes in the back though. </TD></TR></TABLE>
So do I and the front Civic ex/SI (6 gen) and GSR (94-01) are all the same size rotors. So they will fit over the fronts too.
-Shane
-Shane
trigun7469
24
11-29-2005 09:37 PM
