LSD
Re: LSD (civictildeath)
Limited slip differential. It locks the wheels when you are going straight but allows the outer wheel to turn faster than the inside wheel when turning. It's only needed when you put down a bunch of power.
Re: LSD (DOHC4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC4life »</TD></TR><TR><TD CLASS="quote"> It's only needed when you put down a bunch of power.</TD></TR></TABLE>
thats not true, anytime you are looking for better traction a LSD would help greatly. stock or heavily modded a LSD is definatley a worthwhile upgrade.
here this should help
http://auto.howstuffworks.com/differential.htm
Risky Business
Re: LSD (Kamin)
LSD1 ( P ) Pronunciation Key (ls-d)
n.
A crystalline compound, C20H25N3O, derived from lysergic acid and used as a powerful hallucinogenic drug. Also called acid. What civictildeath and all of the 04 members use when posting.
n.
Re: LSD (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">LSD1 ( P ) Pronunciation Key (ls-d)
n.
A crystalline compound, C20H25N3O, derived from lysergic acid and used as a powerful hallucinogenic drug. Also called acid. What civictildeath and all of the 04 members use when posting.</TD></TR></TABLE>
aha aha
n.
aha aha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">
http://auto.howstuffworks.com/differential.htm</TD></TR></TABLE>
Learn somthing new every day. Thank you.
<~~~Knows HOW they work, BTW.
be professional
Re: LSD (DOHC4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHC4life »</TD></TR><TR><TD CLASS="quote">It's only needed when you put down a bunch of power.</TD></TR></TABLE>
As Kamin said, a limited slip diff is beneficial to any application, regardless of power levels. I could have certainly used one at the track this weekend in my 108hp terror
The effects of LSD can be felt/used frequently during any kind of driving. At performance driving events such as autocrosses and track days though, the difference is like night and day - they help enormously. Not to mention they're great for the snow too
Re: LSD (Kamin)
well i should definately look into one cause everywhere i go are winding roads. i rather drive stop and go in town
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">well i should definately look into one cause everywhere i go are winding roads. i rather drive stop and go in town</TD></TR></TABLE>
S <<<<<<<<<thats what these roads look like eats tires and gas slow and go slow and go uphill turn up some more turn
Re: LSD (K I T T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K I T T »</TD></TR><TR><TD CLASS="quote">
???</TD></TR></TABLE>
if they help while turning so well i wont have to slow down as much and waste gas
if they help while turning so well i wont have to slow down as much and waste gas</TD></TR></TABLE>
beef up your suspension if you're want help while turning
i think you should ask yourself the same question you have in your signature.
got suspension tuned already aint enough
how hard are they to install?? how do you install?? DIY thread??
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">how hard are they to install?? how do you install?? DIY thread??</TD></TR></TABLE>
If you have never opened a transmission before, I would not recommend such a task for the do-it-yourselfer. It's not easy, and you will need many tools and a lot of free time.
Re: LSD ([G][A][M][E])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [G »</TD></TR><TR><TD CLASS="quote">[A][M][E]]rs type coilover w/ tokico shocks
front & rear upper strut braces
is not what you would call a <U>Tuned </U>suspension.</TD></TR></TABLE>
i spent months adjusting ride height and stiffness to get the most out of it
Re: LSD (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
If you have never opened a transmission before, I would not recommend such a task for the do-it-yourselfer. It's not easy, and you will need many tools and a lot of free time.</TD></TR></TABLE>
This is one of the "If you've got to ask, you probally can't do it" situations.
Re: LSD (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">time and tools arent the problem. knowing where it goes, how it goes is the problem</TD></TR></TABLE>
You will have to take apart the transmission to install it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
This is one of the "If you've got to ask, you probally can't do it" situations.</TD></TR></TABLE>
I couldn't agree more.
Re: LSD (DOHC4life)
well i got 4 months or so to do it plus my dad was a mechanic what the hell ill learn something else new this year
Guest
Posts: n/a
No, you are the problem.
