Turbo sound on my STOCK D16Z6?!
When im just slowly pressing down on the gas pedal i hear a whining sound that gets louder as i get up in RPM's, not do be a dork but it sounds sort of like a turbo spool up but alot fainter....what is this and can you help me out?
It soundskinda good but im not sure if it IS a good thing.....
and it does have vtec....
Re: (TurboDaveR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboDaveR »</TD></TR><TR><TD CLASS="quote">do you have a turbo?</TD></TR></TABLE>
Damn thats right, i must have forgot ha......pffft NO!
Thanks i guess its the intake
Re: (pdiggitydogg)
i have a whining sound as well, usually in colder temps. starts like 1 second after i start my car. i assume it's the tranny or something like that, maybe one of the accessory pumps. i don't believe it's the filter or intake, cuz i've had more than one setup on my car and still makes it.
it is a cool sound though
Re: (TurboDaveR)
yeah he does states that he does have turbo
Re: Turbo sound on my STOCK D16Z6?! (Cons94)
Mine makes a simular sound. Its my throttle body whisling. I have a CAI so its really loud. You can really hear it from the outside. I hate it cause now theres a big rumor goin around that im turboed, when im really not. It really sucks explaining to people that its not a turbo
Re: (TekSI)
it could also be the timing belt, it could be making the noise, or one of the belts. It happens in my car too. I don't think it's a good thing. I think my timing belt has oil on it from valve cover leaking.
Re: Turbo sound on my STOCK D16Z6?! (TurboTagTeam)
yea im pretty sure its from the intake. I have a aem cold air and it makes the same sound, took it off and now theres no more turbo sound.
Re: Turbo sound on my STOCK D16Z6?! (nighttrain33)
it's weird tho, with mine anyway. it only does it in the cold, the colder it is, the louder it is...is that just from expansion/contraction of the metals in the TB?
Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">Input Shaft bearing</TD></TR></TABLE>
Yep that's what it probably is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cons94 »</TD></TR><TR><TD CLASS="quote">and it does have vtec....</TD></TR></TABLE>
Cause that has alot to do with it and all. Vtec is just like a turbo, thats why it makes that turbo sound. You just cant hear it until you put a intake on it
Re: (MugenDude)
I think its your fuel pump..
Lack of Fuel Pump Fluid sounds similar to an un-tuned turbo engine!
When was the last time you checked it? You might be low on fuel pump fluid. You are supposed to check it every 3,000 miles(with each oil change). If the fuel pump fluid is discolored or gritty you will need to change it.
LOL
LOL
