CLUTCH SLAVE, NEED HELP ASAP!!!
Ok guys, i got a HUUUGGEEE problem. I was drivin to school today and my clutch just stays to the floor. Its not the first time it's happened but this time it wouldnt get back up. I managed to power shift to 3rd to keep drivin and park, but when i got out and looked, the lines were leaking by the shift boot. Ok, i got a ride to get to other places for now, but what can i do to fix this? im ggoing to look for loose stuff near the slave, and add more fluid, anything else i should really be doing and any other cause to this?
Re: CLUTCH SLAVE, NEED HELP ASAP!!! (Apocolipse269)
if you take the little rubber boot off you might be able to see whats going on. the slave cylinder is not very complicated. you might just be better off to find another one in a junkyard.
check inside the car. where the clutch pedal to see if there is a leak or not. like you said you have leak at the slave cylinder then go get a new one at the auto parts store. it does not cost that much.
thanx guys, right now im broke so i guess ill be gettin my buddy to tow it home unless i fix the leak, and untill i get a new slave, im drivin my stepdad's jetta to school & work
HT Order of Merit
Put fluid in it, you should be able to get home. Change the slave and check the master cylinder too, they have a tendency to leak as well. Total cost for a new slave and master cylinder would be no more than 50$.
VTECdohcter
10-30-2007 04:31 AM
GraphiteMW
03-25-2007 09:26 AM
